Loader B3030 with LA 403 loader
/ B3030 with LA 403 loader #1
btrousdell
Amesbury
Kubota B3030
I have been trying to replace the controller for my LA 403 (B2325) I cant seem to operate the bucket properly. I have moved the cables to no avail. The left to right lever control seems to sometimes raise and lower but the tilt functionality doesn't work any which way. Is there a trick to installing this control arm?
/ B3030 with LA 403 loader #2
Quite often with control valve issues we have to back up to the hydraulic line quick connections and find they need replacement.
That was the next thing I cant seem to disconnect one side (Red) of the front bucket disconnects. it seems to have a lot of pressure locking it. how can I relieve that?
/ B3030 with LA 403 loader #4
What I do on my tractors when I get ready to remove the quick connects is to turn the tractor off and move the control levers in all directions until nothing moves and I never have any problems disconnecting. If you still cannot disconnect, you can take a wrench and loosen a fitting on that line to relieve the excess pressure. If that doesn't help, then you probably have a faulty disconnect.
