Struggling getting tractor to start
/ Struggling getting tractor to start #1
OutbackL130
chickamauga
L130, 420
It began with my tractor surging and I would have to pull the choke half way out for the engine to idle. Next thing the engine wouldnt fire unless I poured gas directly into the carb. I decided the carb needed cleaning so I pulled it off and found broken gaskets and loose intake manifold bolts. I cleaned the carb and reinstalled with new gaskets. Turn the key, engine spins but wont fire. Spark is good and it's getting fuel.
I tried to turn the engine over again and the starter would not work! No clicks or noise, nothing at all. It's been doing this occasionally since I got it. When this happens normally on the second attempt it would work, but now it is totally dead. The battery is fully charged. I checked to make sure the shifter is pressing against the neutral safety switch.
Should I at least hear the solenoid clicking if it was a bad starter?
/ Struggling getting tractor to start #2
How many volts are in the battery?
Are the cables clean?
New cables and 12.5 volts.
I was wondering how do you rule out the solenoid?
/ Struggling getting tractor to start #4
Take a test light or meter and see if you have power to the starter with key to start.
2020 DRAGON 150BBL ALUMINUM (A63569)
2020 DRAGON 150BBL...
2001 John Deere 1780 Planter (A63109)
2001 John Deere...
Case TV380 (A62177)
Case TV380 (A62177)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
iDrive TDS-2010H...
