GM unveils new 6.2 1/2t specs
   / GM unveils new 6.2 1/2t specs
Not to mention EB doesn't require premium fuel and doesn't have AFM which I don't trust.
I trust them as much as I would any engine with direct injection, twin turbos and DOHCs.
   / GM unveils new 6.2 1/2t specs #62
I heard GM is having problems with AFM on the trucks.
Sent from my Samsung SPH-L710 using TractorByNet
The older 5.3s develop oil consumption. Not all do. The ones that are used for primarily light load highway driving do it much more.
   / GM unveils new 6.2 1/2t specs #64
So, the ones that tend to go into 4 cylinder mode seem to have more problems. So, basically, that means they are having problems with AFM.
Yes. But I also know that they have made some changes to the crankcase ventilation. The light load seems to also be affecting oill consumption and not just the variable cylinder management
   / GM unveils new 6.2 1/2t specs #66
While I won't say that I don't trust AFM, it hasn't been shown to be as effective as some once thought.
It would be interesting to see an EB with AFM. A single turbo pushing 3 cylinders of a V6? Hmmm....
I think the next real advancement in engines and fuel economy technology is going to be electronically actuated valves. Can you imagine removing all of the hardware and friction that goes along with it?
I fly a Ford executive quite often. I asked 6 months ago if AFM would make into the Eco or 5.0. Answer was no. To many associated issues right now with it. They are competitive without it.
Chris
   / GM unveils new 6.2 1/2t specs #67
Chris,
These are deadhead (empty cargo) numbers...don't the diesels shine when loaded vs. gassers?
If so, what this says is diesels ain't for the grocery-getter set anymore.
Yes, any day of the week. Have you priced out a diesel option though? You are talking $10,000 plus. That buys a lot of gas at $3.49 vs $4.00 for diesel to gain 2 to 3 mpg.
Chris
   / GM unveils new 6.2 1/2t specs #68
Thanks to Peacock for the Pickuptrucks.com reference. They deserve kudos for trying a real world approach and being transparent about their methods which are a mix of subjective, calculated, and measured. I looked at one of their measured methods, MPG. Their loaded MPG ranges from 12.6 (Chevy) to 10.4 (Dodge). The middle of that range is 11.5. That means MPG in their test fleet was 11.5 plus or minus 10%. Not all that much difference when you think of the variation you can get in the same vehicle from driver to driver. Gas is costly so small differences add up over time. Still, I come away thinking about how similar these vehicles are (on loaded MPG) rather than how different.
They generally do excellent comparison tests.
As competitive as the light truck field is the pack is going to be pretty tight.
   / GM unveils new 6.2 1/2t specs #70
Chris
Which one do you fly? That would be awesome to have a nice conversation with one of them. I would love to sit down with Alan Mulally. He seems like a generally great person.
I've heard that AFM is much more difficult to implement on an OHC engine vs. an OHV engine too.
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
