Front axle pinion removal
/ Front axle pinion removal #1
allsizepro
Kioti LK3054
Hi,
Anyone know an easy way to attach a slide hammer to the pinion shaft on the front axle of a 4110?
As you can see in the picture there is nothing to attach the slide hammer to.
/ Front axle pinion removal #2
why would you want to attach a slide hammer?
Remove that seal and then take the nut loose!
/ Front axle pinion removal #3
Take the drive shaft coupler, weld a nut to the other end for the slide hammer, slot the other end, . Take small muffler clamp and clamp it to the pinion. It works well.
/ Front axle pinion removal #4
Wallace's exploded view shows you do not need a slide hammer. It dose look like a nut and an snap ring holding things together behind the seal. It seems that if you needed a slide hammer to remove, the hole at the end of the pinion shaft would be threaded. Just my :2cents:
/ Front axle pinion removal #5
You will need a slide hammer. New England described the set up you need. You will need to buy another coupler but there inexpensive. The nut just holds the bearing on the shaft.
PORTA POTTY (A68842)
2015 BIG TEX T/A UTILITY TRAILER (A67714)
2015 BIG TEX T/A...
2016 Nissan Altima Sedan (A66738)
2016 Nissan Altima...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
2002 Lexus RX 300 SUV (A66738)
2002 Lexus RX 300...
2017 CATERPILLAR 336FL EXCAVATOR (A65056)
2017 CATERPILLAR...
