Is retrofitting a DPF possible?
/ Is retrofitting a DPF possible? #1
soko
Wandi, WA
Hinomoto
I have a Hinomoto C174 19hp tractor and am a little worried about my own health sitting so close to the exhaust, breathing in diesel soot and fumes etc. Is it possible and worth retrofitting a filter (DPF) and has anyone done such a thing on a comparable tractor before?
Thanks for your help from Western Australia!
Soren
/ Is retrofitting a DPF possible? #3
Can't you reroute the exhaust?
Yeah. This is way better than adding a DPF. Everyone around here is trying to figure out how they can take them off.
/ Is retrofitting a DPF possible? #4
You would need to add a DPF filter ($300-$400) into the exhaust, as close as possible to the exhaust manifold as it needs to run hot. Then you would need to add a pump and an injector ($??) to inject diesel fuel into the filter to burn off the trapped particles and you would need to add a way to control the injector.
I would just re-route the exhaust pipe if you are worried about the fumes.
Ok, ok, I got it, far too complicated and expensive.:eek: So, if I re-route the exhaust, could I get problems with a longer pipe or can I make it as long as I wish, in theory?
/ Is retrofitting a DPF possible? #6
Unless you put extreme bends in the exhaust pipes that caused a big increase in back pressure, you can make them as long as you want (within reason). I'd keep the muffler roughly the same distance from the exhaust manifold to avoid any significant changes....adding a couple of feet to the tail pipe isn't going to cause you problems.
Thanks guys, good to have good and quick advice at hand.
/ Is retrofitting a DPF possible? #8
Looking at it from another perspective, you could:
Wear respirator made for particulates.
Run biodiesel (maybe cleaner and less harmful).
Build/buy a filtered enclosed cab.
Sell the diesel and buy a gas tractor.
Replace the tractor with horse. Just kidding.
I wonder what the long term effects will play out to be. Especially for occasional use/hobby tractor groups. Seems nowadays long term health is about balancing risk vs benefits as well as the set of genes you are equipped with.
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
Wacker Neuson RD12 Tandem Vibratory Smooth Drum Roller (A64553)
Wacker Neuson RD12...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2008 KOMATSU PC78MR-6 EXCAVATOR (A65053)
2008 KOMATSU...
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A64556)
2014 Hyundai...
