JD 5603 suddenly won't move
/ JD 5603 suddenly won't move #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
My neighbor unloaded an 18 wheeler load of rd bales(38) and parked tractor.Went back an hour or so later to unload another 18 wheeler load of rd bales and tractor won't move. Loader works fine neutral light on dash goes off in both F & R but tractor just sits still. Anyone know where to look for fuse or relay?Thanks,Jim
PS: I hate electronicallly controlled hyd functions
/ JD 5603 suddenly won't move #2
Is the neutral light flashing?
Is it in a range?
In gear?
D.
Neutral light is on solid in neutral and goes off when shuttle is shifted to fwd or rev. I tried shifting in all gears & hi/lo. dealer serviceman worked on it several hrs yesterday & no go.
Neighbor told me yesterday he's so disgusted that He want's to sell this cab JD for wholesale price and buy an older tractor to fill tub grinder.
/ JD 5603 suddenly won't move #6
Probably something simple. Surprised the dealer could not figure it out.
D.
D.
4 hrs service call @ $85 per hr plus 2 trips of mileage doesn't sound cheap to me with no moving tractor. The technician stated tractor needed to be hauled to dealership.
/ JD 5603 suddenly won't move #8
Probably be cheaper if it was hauled to the dealers straight away and not let the technician fiddle around for four hours doing nothing. Hope your neighbors tractor gets fixed.
/ JD 5603 suddenly won't move #9
Check the clutch pedal switch and sensor. Sounds like computer thinks clutch pedal is depressed.
I agree sometimes it's better to take to dealership especially from my point of view as a retired JD dealer service manager. I hope he get's it repaired so he'll stop bugging me about a tractor I know very little about.
Surely the JD tech checked the switches but I'll notify tractor owner. Thanks,Jim
/ JD 5603 suddenly won't move #14
I had the same thing happen to my 4520 cab tractor. I had been out mowing most of the morning. I put it in the barn while I grabbed some lunch. Came out and it would not start. Not turn over, nothing. Ended up being the computer. It was under warranty but I was more pissed about the loss in production that day. Oh well - it got done anyway = just unwanted.
D.
/ JD 5603 suddenly won't move #15
... tractor won't move ... neutral light on dash goes off ...
Old thread resurrected lol
What was wrong with your neighbors tractor ?
Center hub of traction clutch stripped out. Tractor required new clutch assembly installed.
/ JD 5603 suddenly won't move #17
Sounds EXPENSIVE.
Mine pulls fine WHEN lights don't flash.
/ JD 5603 suddenly won't move #18
That is a pretty weird breakdown! Work in' fine.. No noise, no slipping, no sudden stop and engine windup...
Would have never guessed the clutch blew!
I agree but this particular tractor gets several different daily operators. It also has unloaded/loaded many,many rd bales.
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2015 Ford F-550 Utility/ Plumbing Truck, VIN # 1FDUF5GYXFED42880 (A65563)
2015 Ford F-550...
40' One-Trip Shipping Container (A66285)
40' One-Trip...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
CLUB CAR  CARRYALL 6 (A65643)
CLUB CAR CARRYALL...
(1) Texas Built...
