Simple Utilitarian and Cheap Table for Wood Splitter
/ Simple Utilitarian and Cheap Table for Wood Splitter #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I made a 20 wide X 16 inch deep table for my splitter from some scraps of angle and flat stock I had. I wanted the table removable so I welded two mounting ears to the splitter and attached the table to them with two bolts. The top is just a piece of scrap 5/8" CDX plywood with a 16 gauge (1/16") steel skin glued on with Gorrilla glue.
/ Simple Utilitarian and Cheap Table for Wood Splitter #2
Nice idea. My shop workbench has lasted for years with the addition of the metal over wood. Grapple has me wanting.
/ Simple Utilitarian and Cheap Table for Wood Splitter #3
I like your idea very much. I'm going to do something similar. Thanks for showing it.
Phil
/ Simple Utilitarian and Cheap Table for Wood Splitter #4
Thanks I am putting one on mine this year and you just gave me an idea.
/ Simple Utilitarian and Cheap Table for Wood Splitter #5
Looks good. I'm going to do something very similar. Thanks for sharing.
Eddie
/ Simple Utilitarian and Cheap Table for Wood Splitter #6
I am also thinking of a table for my splitter. but I need one on the end to catch the wood as it slides past the wedge. Thanks for the idea, wood is cheaper than metal, and I have the wood already.
/ Simple Utilitarian and Cheap Table for Wood Splitter #7
Tables makes it easy when handling huge logs :thumbsup:
we have split ouer firewood with water hydralics over 20 years
Plywood tables funktions quite allright.
/ Simple Utilitarian and Cheap Table for Wood Splitter #8
Here is a simple design of a wood and metal out feed table that is removable,,
/ Simple Utilitarian and Cheap Table for Wood Splitter #9
Nicely done, Gordon.
You just don't see O/A fusion welds much these days.
It's becoming a lost art.
I need to do something similar with my splitter to reduce the amount of material handling I'm doing with big rounds.
-Jim
/ Simple Utilitarian and Cheap Table for Wood Splitter #10
Why did you need to make it removable? I welded a 1/4 inch table to each side of my splitter when I got it.
Pan
/ Simple Utilitarian and Cheap Table for Wood Splitter #11
Looks good. I have the same splitter and am wanting a table. Thanks for the ideas.
/ Simple Utilitarian and Cheap Table for Wood Splitter #13
Thanks to you, this is my rendition of a cradle / table.... This is only my second welding task ever. Thus far I am happy with the design. I hope it works.
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
bad boy zero turn 72 (A56859)
bad boy zero turn...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2005 GMC C7500 24FT BOX TRUCK (A59904)
2005 GMC C7500...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
