B2400 starting problem finally solved
/ B2400 starting problem finally solved #41
I had the same issue with our BX2200 for over 2 years. Had it to the dealer twice but it wouldnt act up for them. They just said I wasnt starting it right, b/c you know after 10 years I suddenly forgot how to start it. Anyway 10 min on google I found this thread. Picked up the kit from a JD dealer and 15min later the kubota starts the first time every time. Its never going back to that dealer again.
Thanks
/ B2400 starting problem finally solved #42
Well, I must be the laziest son-of-a-gun on this board. 10-years ago I wrote that my B2400 was getting hard to start and I need to look into this fix.
Well, here we are 10 years later and the B2400 is still hard to start. As I said 'way back when, it's more annoying that serious but she still starts eventually and still runs great. In the imterim I completely forgot about this simple fix. Thank you to whoever bumped this thread. I'll get back to you in another 10-years and tell you how it worked out. :)
/ B2400 starting problem finally solved #43
I'm glad I found this thread. I've had no problems starting my B2400 for the 3 years I've owned it, but suddenly today it won't start - the solenoid doesn't even click. I measured about 5 V getting to the solenoid when I turn the switch, and the starter engages fine when I jump directly from the battery to the solenoid, so I believe this fix will take care of my problem.
I hope to be able to report another satisfied customer in a week or so, after the relay arrives.
/ B2400 starting problem finally solved #44
Hi All,
Since this thread should be immortal, I'll jump in too.
I've got a B series with same symptoms - a B7620, but have a question. Isn't this fix bypassing the original starter relay for the thing? Why not just replace the original starter relay with a low voltage relay?
I haven't dug into it very much yet, I found this thread first (how LUCKY for me !!) before replacing the battery, starter solenoid, starter etc. I'm sure glad my K is stuck in the back of a lineup of things to get out of the way, or I wouldn't have decided to investigate/Google for an answer. I mean, it's just plain obvious - it MUST be the battery! :eek:
Thanks once more kubmech!
I'm going to do some digging to find out more - so I may come up with an answer to my own question above. Like, I'm already thinking - maybe this beast doesn't have a starter relay before the solenoid? Or, it's been put in a nice safe place where you can only reach it with a special dealer-only tool? etc.
/ B2400 starting problem finally solved #45
This fix doesn't bypass the original starting relay - the new low-voltage relay is used to engage the original relay.
As for replacing the original with a low-voltage one, it may be that it's more expensive to buy a low-voltage relay that can handle the current of the starter motor compared to one that only has to power the solenoid (but I'm just guessing).
Also, I'm pleased to report that my tractor has been starting reliably since I install the low voltage relay a few weeks ago.
/ B2400 starting problem finally solved #46
Great news about the reliable starting. I hope I'm in the same crowd soon.
Do you (or anyone) know where the black/white lead comes from? I thought it must have come from the starter relay to activate the solenoid, but from the component diagrams at the Kubota site, I can't identify which items connect to what. If anybody knows of any wiring diagrams or schematics they'd sure come in handy...
(they do make it hard to get into these, don't they ;-)
/ B2400 starting problem finally solved #47
I have a Lastec 3372 with a 33 HP Kubota diesel engine. Same problem as most posts; that is, it clicks when I turn and release the ignition switch key. Cleaned battery posts and cables and also the battery ground connection. I'm hoping the modification kit will work for my situation. Does anyone know how to specifically get to the KubotaMech post referred to earlier in this thread. When I click on the link given, it does not take me to the post???
/ B2400 starting problem finally solved #48
/ B2400 starting problem finally solved #50
I'm new here ...I clicked the link but I do not see the post?
Thanks
Bj
This is what is in the post, the only reason I took the time to do this is b/c i was ripping my hair out when I had this issue with my BX2200, the kubota dealer had the tractor twice and didnt figure it out. The Kubota let me down a couple times when I really needed it and I had to drag it onto a trailer with a ratchet strap. I bought the kit from a John Deer dealer and have had no problems for since. going on 4 years.
origional post by kumech
Frank, heres the bottom line..Power flows from your ignition switch through your PTO, neutral and clutch safety switches.
To the starter solenoid (black/white wire??) When all the switches and battery etc. are new there is very little resistance.
After you get some time and some age in these components resistance builds up and eventually will cause a voltage drop by the time it gets to the starter solenoid. This voltage drop will vary according to temperature, humidity and other factors.
That's why some times it'll work and other times it wont. The starter solenoid needs approx. 9 volts to fully engage. Anything less and it wont fully make contact to send power to run the starter motor. Yes it will click, but needs just a little more "oomph" to fully seat on the contacts and allow the starter motor portion to run. Now instead of replacing all the components in the system to reduce the voltage drop. What you need to do is install a starter relay. Most, if not all modern machines have this feature now because of this very problem. Some companies figured this out a bit sooner than others and came up with a pre-wired relay kit with instructions (John Deere and Scag I know for sure). Now some guys like to do things on there own and run down to NAPA and get a regular low voltage relay or a good old fashion starter solenoid, wire it up themselves and fix this problem, which works just fine. However the good old fashion starter solenoids still need close to 9 volts to engage and still causes some problems. The low voltage relay is the best way to go.. I think it will work with as low as 4 volts. In my experience the easiest way to go, is to install the JD kit part #
AM107421. It's, like I said, prewired and comes with instructions and it's around 15-20 bucks. Basically the way it works is... The red wire goes to the Battery terminal of the starter, the black wire goes to ground. You plug the black/white lead that would normally go to your starter to the male purple connector of the relay and the female connector purple lead to the starter. I have solved this "mysterious" problem many, many times on all brands and models of older machines with this kit. Everyone has given great suggestions for making sure your basic electrical system is sound and in proper working order. Most times when all else checks out and I have verified that voltage to the starter solenoid is a little low or questionable, installing this kit solves the problem at least 99% of the time. I'd be willing to bet it will work in your case as well. On rare occasions I have torn down the starter to find the contacts bad in the solenoid when this kit would not solve the problem. However for the price of the kit it's more than worth a shot in my opinion..................
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
Iranch IRET13 (A60463)
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
