1428v third function
/ 1428v third function #1
boondocker
sand lake new york
massey furguson 1428v
looking for diagrams for adding rear remotes to my 1428v. Need to know where the power beyond connects back to the hydraulic system, any help would be appreciated
/ 1428v third function #2
Do you have a loader? If you have a loader, the loader valve should have 7 lines off of it. 4 that take care of the loader functions and 3 that service the valve. You should be able to plumb everything from those 3 lines. You should be able to follow the PB line from the FEL valve.
/ 1428v third function #3
Hydraulics:
Pressure: 2134 psi [147.1 bar]
Total flow: 10 gpm [37.9 lpm]
Steering flow: 2.6 gpm [9.8 lpm]
Is your tractor open center hyd system or closed center hyd system?
It is different for different tractors.
Some add 3rd functions directly off the loader valve, and some obtain the flow from a hyd block, and some use ports in the tractor body.
Is your 3rd function considered a rear remote, or will you use it for a grapple? Will it be lever valve or solenoid valve?
How many QD sets do you need?
Your flow path might be like this, pump ,loader, 3rd function, 3pt, and tank.
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
6' 3Pt Disk (A66285)
1994 John Deere 8300 (A64126)
1994 John Deere...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
