vista laptop - security center empty, firewall not on, can't update, add/remove prog
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #31
I have no clue how / why he even turned off the firewall to beginwith??
in any case. i just ran the MS fix it..wouldn't run. tried the offline fix it where you download fix it to a removeable media drive on a clean computer and then walk it over...then run it. still would not run ;)
Try this one:
Some services do not start in Windows Vista and Windows 7
Might also try removing Kaspersky and re-installing it per Windows Security Center, Firewall and Defender Will Not Turn On? - Microsoft Community
Aaron Z
I don't think there is a nasty still there... I think I'm just dealing with trying to stitch the would the nasty left.
I've already booted using a cd with linux ( no viri.... ) and done a full virus and malware scan. nada....
that's the perplexing part..
doing the sfc /scannow as we speak...
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #34
Its probbaly Windows making a mess of itself itself. Re-install is the easiest way to fix, but removing Kaspersky and re-installing it may fix it.
Aaron Z
the sfc just finished. made a 7meg log file that looks greek to me. ;)
going to reboot the machine and see what if anything works on it now. :0
boo hiss
the hp recovery software is very limited in options.
I have seen some that simply let you 'repair' the OS instalation.. but keep user files and installed software.
the hp software is all or nothing... return to as purchased state.
UGH........ :)
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #37
boo hiss
UGH........ :)
Try the links here: downloads'n'fix: Microsoft Windows Vista Official .iso Download Links (Digital River)
Should let you create a boot CD and do a repair install from that.
Hate the all or nothing nature of the recovery partition.
Aaron Z
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #38
Well, time to get new laptops huh? "Um, sorry man, tried everything I could find and its still hosed. Too expensive to take it in, so I advise its time for an upgrade. I found several excellent Win8 i5 laptops for less than $800 each." :thumbsup:
Or, try Combofix :p
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #39
Or, try Combofix :p
The problem is that those laptops would be that they have Windows 8 on them...
When it comes to Windows: XP > Vista. 7 > Vista. 7 > 8.
Aaron Z
   / vista laptop - security center empty, firewall not on, can't update, add/remove prog #40
While I agree Win8 could use some help, its basically Win7 (the greatest, btw ;)) with a new shell.. They can get new ones with Win7, but XP is out as the support is ending soon.
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A56435)
2025 Mahindra 6075...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
2019 Freightliner M2 106 Flatbed Hauler Truck (A55973)
2019 Freightliner...
2012 Ford F-550 (A55973)
2012 Ford F-550...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
