Which type of welder would be best for my needs?
/ Which type of welder would be best for my needs? #1
sdef
SC
2013 Kioti DK45SE HST
Good day. I am envisioning a need for a decent welder to modify and repair small farm equipment, but am in a quandry about which type would be best for my purposes- a wire feed/MIG or a stick. I am considering the Everlast PowerArc 200 stick and the Hobart 500559 MIG.
Welding is not a current skill I have, but I am a quick learner and mechanically inclined.
My goal would be to repair damaged equipment like buckets and box blades or to attach heavy duty mounting points, etc. I am thinking about adding probably 1/8" - 1/4" thick metal and potentially repairing 1/8" - 3/8" metal (and possibly limited 1/2"), all mild steel.
I do not currently have a 220VAC 50 amp or so spare circuit in my current home but will have plenty of power in my new home a year from now. However, I currently have a 8.5K generator that should run any welder I would be purchasing.
It would also be nice to be able to weld thinner materials, but this would be a secondary objective.
I have been investigating this subject for some time now, am stuck at this point and am not able to afford two welders at this moment. I have a new tractor and implements coming and am purchasing bolt-on doodads, such as grab hooks for the bucket and would rather have weld-on items.
Experienced advice would be greatly appreciated and thanks in advance to all who respond.
/ Which type of welder would be best for my needs? #2
Mig / wire feeders are great for production work. But a lot of things can go wrong with them. Stick welder is about as simple as it gets. For now you can buy a good DC stick welder, and a air cooled scratch start Tig torch for the thinner projects.
/ Which type of welder would be best for my needs? #3
DSCF0525.JPGIMG_20121117_165303_772.jpgIMG_20121117_165336_859.jpgPicture 006.jpgPicture 011.jpgDSCF0450.JPG
If you want to weld on some bucket hooks or repair a broken implement a stickwelder will certainly do that. They are simple, cheap and easy once you get the hang of it. And they make Strong welds. I have a little PA160 and it does all I have wanted.. I TIG with it too for thin metals, steel, copper, brass. No Aluminum as it is just DC. I have repaired a lot of things with it in the last 3 years.
James K0UA
/ Which type of welder would be best for my needs? #4
Shield Arc gives good advice as is his norm.
MIG welders have many disadvantages on the farm in my opinion.
>Needs sparkly clean metal
>Can't be used in any wind
>Difficult to haul around
>Lots of moving parts to cause mechanical difficulties
>Unless talented, MIG welds can be iffy
>Less adaptability to the conditions/materials - with stick you just switch rods and amps
>More expensive to buy and maintain
Stick
>Inexpensive
>Adaptable
-like hardfacing implements, welding through rust and debris, deep penetration (think bucket hooks), and so forth
>Lightweight (Inverters)
>Your generator should work
I have the PA 200 and it works quite well.
/ Which type of welder would be best for my needs? #5
Here what I use,, had it for about ten years,, 10k watts and welder,, tractor supply,, I fab the trailer myself,, hook it on the back of the gator and pull it anywhere I need it.. Lou
View attachment 334037View attachment 334038View attachment 334039View attachment 334040View attachment 334041View attachment 334042
James K0UA
James. Really nice looking weld on that grab hook. So 160 amp stick is all I may need. Nice since the 200 is currently unavailable on Amazon.
I like that trailer and had not considered it as an option. Hmmmm.
Each of you have expressed opinions I have been considering and the stick was heading up my list. Thanks guys, I will get a stick and not look back.
/ Which type of welder would be best for my needs? #9
I would go with the PA-300, or Longevity's Stickweld 250. That way you get adjustable hot start, and arc force!:cool2:
What ever you buy, don't go through Amazon! Buy it here.;)
/ Which type of welder would be best for my needs? #10
If buying from Everlast or Longevity, PM them here and they may beat the price on Amazon...
Aaron Z
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
7' Chisel Plow (A60463)
7' Chisel Plow...
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
2007 PACE AMERICAN 14 T/A DOG HOUSE (A60736)
2007 PACE AMERICAN...
2014 FORD F-550 XL SUPER DUTY UTILTY/SERVICE TRK (A59823)
2014 FORD F-550 XL...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A62130)
2008 FORD F350 XL...
