tail light convertors
/ tail light convertors #1
radioman
Super Member
Ontario, NY
Kubota BX24
Long story short - I just hooked up my 16 ft landscape trailer to my kia sedona couple days ago to pick up a cub cadet tractor to fix for a freind. I checked the tail lights to make sure its all working before heading down the road and no lights. what?! Was working beginning of the summer. So I say to myself, okay - lets make some simple checks. took my trusty light tester and found no power coming out of rv plug on vehicle side. Thought it was fuse, nothing. cut wire?nope. bad ground? cleaned the ground and recrimped new connectors on it just to be sure. nope. traced the wire back to the taillight and found there is power/signals going into the taillight converter , but nothing coming out.
Sigh! 50 bucks down the drain.
My question is , should I buy the cheapest converter and splice in the oem y connectors from my old one or go ahead and buy the "correct one" for my vehicle? Why would it fail? its a plastic sealed box with wires coming out and I dont know if it repairable. Once I order a replacement, I might cut one apart and post here what I find unless someone has done this already and if it worth the effort to mess with it?
/ tail light convertors #2
/ tail light convertors #3
Most of those are just diode bridge arrays and are quite limited in the amperage they can carry. I found some 5 to 4 converters on a boating site and bought 5 of them, they were like $3 ea. Google search and get a couple of the less expensive ones, usually buying more than one won't cost more to ship and you'll have a spare or for another rig. Also, you might consider switching the trailer lights to led ones to get less current drain and not overtax the converter box.
thanks guys .. I already switched tail lights to leds last fall, but the sidemarkers are still bulbs.
On a side note, I forgot to add to a long story, but my friend I was going to get his tractor for tried hooking up his suv to my trailer and found that he has running lights constantly even if vehicle running lights was off. He also cannot get any left/right turn signal. Traced his wiring and it went to his tail light converter too. The odd thing I saw was the brake output was connected to vehicle ground. It was installed by uhaul recently and they apparently didnt do it right. he was pissed saying they were supposed to be professionals and they did the job cheaper then I quoted for :rolleyes:.
As for 3 bucks each, I did a google search but only found 7 bucks each.
/ tail light convertors #5
I'm not really a fan of converters.
On my utility trailer, I installed a second set of signal lights, with their own 2'nd plug. If you can dedicate this trailer to your vehicle (as opposed to legally loaning to just anybody), then having a non-standard (as in needing 2 connectors on the vehicle) hookup is no big deal.
Rgds, D.
/ tail light convertors #6
I should have clarified that it was several years ago when I bought them. Just pulled my file for 2008 and it was $16.11 for 4 of them, so I was wrong on the quantity as well. Guess I can quit looking for the missing one now.
I'd still opt for the less expensive ones and having a spare; as you've discovered, paying top dollar doesn't always mean better.
/ tail light convertors #7
One note of caution, I put amber oval LED marker lights on the front side of the fenders of my trailer. They were far too bright, and extremely annoying to see in the rear view mirrors. Otherwise, LED lights are nice.
Depending on how you use your vehicle, I'd keep everything "standard" so you can yank any trailer without rigging special lights.
The Converters seem to be a simple way to go.
Is it a simple set of diodes?
Ground --> Ground
Taillights --> Taillights
Right Signal --> Right Signal
Left Signal --> Left Signal
Brake --> Diode --> Right Signal
Brake --> Diode --> Left Signal.
Is there risk of other feedback? Anyway, you might be able to make your own converter box using decent components.
/ tail light convertors #8
About 20 years ago I bought some diodes for a few dollars from Radio Shack and made my own converter. It was still working when I sold the truck.
I don't remember the wiring diagram but it was simple to figure out. Probably find it online now.
Bruce
/ tail light convertors #9
Do not want to derail the thread but
Do LED trailer lights not work on vehicle hookups just like normal trailer lights?
Can you not plug into a trailer that has LED lights without a special mod?
/ tail light convertors #10
The reason I brought up the LED issue is that the converters that I got said in the instructions not to overload the unit by having more than one vehicle and one trailer light per circuit, not counting marker lights which don't go through the box.
LED lights work just the same as, and are interchangeable with sealed beam lights, they just draw far less current, are longer lived due to resistance to vibration and heat burnout.
The whole purpose of the converter box is to take the signals from the combo lights used on primarily import vehicles and split them into the standard trailer configuration where turn signal and stop share the same filament.
So a trailer that had LED's in a standard 4 config would work equally well on an old Chevy that has no need for a converter to the trailer plug as on my Toyota that has the 5 to 4 box wired in. Hope that makes sense.
/ tail light convertors #11
Thanks
I was wondering what I was missing as I thought it was transparent between the two but one can always learn.
/ tail light convertors #12
We just buy the cheap converters. They do go bad from time to time.
Chris
/ tail light convertors #13
A cheap converter is fine for a small utility trailer with just a pair of taillights, license plate light and side marker lights. More elaborate lighting may need a converter with a direct 12 volt line from the battery. As for LED lights, they should be no problem because they use less power than incandescent bulbs.
looks like I am going to order a few. one to go on van and few more for backup. I hate not having anything not ready to go at moment's notice.
/ tail light convertors #15
did i read "kia sedona", "16ft trailer", and "tractor" all in the same sentance?
/ tail light convertors #17
Quote Originally Posted by some zilch View Post
yes .. problem? ;)
Maybe the tractor is pulling the trailer with the Kia on it? :laughing:
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A64556)
2018 Nissan Titan...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
2025 SGB20 20in Hydraulic Grapple Stump Bucket (A64553)
2025 SGB20 20in...
