power trac 1850 control issues
/ power trac 1850 control issues #1
power trac 1850
harvey lake PA
power trac 1850
i purchased a power trac 1850 on the cheap . I like problems .the info i received with it is useless , and with the fresh
coat of red . cant read anything . Can anyone post pictures of controls ,or point me in right direction ? Manuals ? for sale or on line ?
Can only get 2 wheels turning to start with . Thanks for any help i receive . Will not be my last post . Will try to post pictures .
Thanks Kevin In PA
/ power trac 1850 control issues #2
Hi Kevin,
Welcome to the Power-Trac forum.
There are several people here that own 1850's.
Don't know about the manuals, as they are very poor.
/ power trac 1850 control issues #5
Kevin. I am happy to help,so will be ken the other 1850 owner. Big thing we need is some pictures of your machine. While pt doesn't change much we are all always surprised by changes.
I think my big questions are.....n what're kind of engine do you have? When you operate the treadle, the foot controls, are there hydraulic hoses connected to them or cables?
All the pt's have the same basic design, and the guys in this group are amazingly helpful.
/ power trac 1850 control issues #6
As JJ said, the manuals are terrible. They give you NO useful information, not even how to start or stop.
/ power trac 1850 control issues #7
Perhaps you can tell us more about your machine , such as how old, which engine, pump manufacturer, size tires, dual tires, how many attachments, etc,
I would highly recommend a 3000 psi gage to help you monitor and trouble shoot the hyd system.
If you know how to use the search engine, you might just read everything that has been posted about the 1850 till now, plus ask all the questions you want.
I have a PT-1445, but might be able to help a little.
/ power trac 1850 control issues #8
If you go to Search Results - TractorByNet.com that should list all threads with the number 1850 and either PT or Power Trac.
Aaron Z
image.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpgimage.jpg
Spoke to terry machine us a 94. Will replace
Gage . Will Chechnya if front pedals are
Connected to hose or cable . Have with
It plow and tractor bucket. Looking to get
Brush hog when working.
Thanks for all the replies keep them coming
Kevin. Hope pictures come out
/ power trac 1850 control issues #10
WOW. Completely different than Either Ken or My 1850, but I think JJ's 1430 has some similarity.
Evertthing so far makes sense, except for the lever on the center column. JJ, any ideas?
So you have got it running? engine turns over? And then you take the brake off (this would be the handle on the left side in front of your knee, it is the brake as well as the brake release). so that you know, there is no braking on a PT, for the most part they hold position on hills pretty well when running, but of course you need them with the engine off.
I am pretty sure you have a cable drive for the wheels, which means the foot pedals use a cable run to the hydraulics on the engine that either push fluid forward or reverse. Newer models use hydrualic lines to provide that control.
Does your PT steer? Does the arms move up and down?
My PT has 3 different hydraulic pumps. One drives the wheels only. One drives the steering, lift tilt dump, tilt seat, and float (maybe brakes, never checked that). The last pump is purely the PTO pump. Hopefully this info will help you start to suss out the drive train issue.
/ power trac 1850 control issues #11
thanks for the reply so know i know that levers the brake . Engine runs < needs a new fuel solenoid will work on it this weekend . Steers well .
front controls move up and down seat tilts when it wants ::. any idea lever near nee is? I am sure i will figure it out in time . Sure would be nice to have a manual . what i have is parts manual
for a few selected parts , thanks again for help Hope to get it squared out to plow this winter , But time goes fast kevin carty
/ power trac 1850 control issues #13
Welcome Kevin.. The lever by your knee on the right side would be used as the control for the quick attach plate on the newer machines but on yours (probably is a 3 point attachment method like mine) it is used to angle the snow blade ,etc. The hydraulic cylinder for the seat probably needs the air bled out of it or at least that was the trouble with mine . I have a 1996 1845 pt which is very much the same as yours.
/ power trac 1850 control issues #14
If that lever moves the third spool on the valve, it is called aux lever on my 1445 and is for whatever you want it to be.
That is probably an Isuzu truck engine, and is water cooled using a radiator.
The engine on my 1445 is a Ford 4 cyl industrial engine, and water cooled.
If you don't have a solenoid switch for the PTO, then the lever lower down, might be the hyd variable speed control for the PTO.
2017 BOBCAT MT55 STAND-ON SKID STEER (A64279)
2017 BOBCAT MT55...
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2019 Forest River R-Pod RP-191 Travel Trailer (A61574)
2019 Forest River...
