Tilt Trailers and load balance
/ Tilt Trailers and load balance #1
HappyOne
North Central OK
L5740HSTC
I am fed up with slide in ramps and don't like flip up ramps so I have decided to look at tilt trailers. I like the way Kaufman does their split tilt trailers. I have a second property to mow and would like to be able to take both a Zero Turn and my L5740 with a woods RD8400 on back. The trailer pictured below has a 10' fixed deck and a 14'6 tilt deck. My ZT is 7'5" long and the tractor with mower is 14'4" from the center of the front axle to the rear of the mower. My thought is to load the ZT first backing it up to the front of the trailer. Then load the tractor.
My thought is once the tilt has enough weight to lay down, where should the tractor stop. The ZD in question weighs 1400lbs so I'll have plenty of tongue weight. The tractor weight could be centered on the rear axles. Does this sound like a workable plan?
On tilt trailers in general, once you pull on far enough to tilt back flat, is that general far enough to balance the tongue weight?
This 24' 15k (14k) is about as long as I feel comfortable hauling. I would be interested in other brands with split decks and at least 8' of fixed.
/ Tilt Trailers and load balance #2
I too got tired of using ramps. In late 2005 I bought a new 2006 20' MX speedloader from an H&H Trailer dealer. I have used the trailer quite a bit and like the way it handles. Mine is a bumper pull but they have goose necks also. I also changed mine from manual tilt (using the manual hyd. jack) to electric / hyd. and added a winch. Mine is power up and gravity down using the lever on the power unit to release pressure. That means it stays tilted till I release pressure on the pump. Check HHtrailer.com to look at their models. On the gravity tilt you mentioned once you pull on far enough to tilt it down I pull fwd. another foot or so but that may differ depending on brand.
/ Tilt Trailers and load balance #3
I bought a Cam tilt (16,000lb) a few years ago, never again. I have a stationary 3' forward deck to carry my excavator buckets, compactor etc and a 16' tilt. The issue I have is I can take nothing in tow and cannot take two tractors. At the time I purchased it I was mainly hauling my ecavator, but as my farm has grown I cannot haul things like manure spreader and tractor, haybine and tractor, baler and tractor etc....
That's why I want a 8' or larger fixed deck. I can see where a tilt deck is limiting. I just sold my Land Pride AFM and there would be no way to haul that with a tilt. I might regret the purchase some day, but right now we make two trips and hooking up the ramps and stowing them 8 to 9 times a day is robbing us of time. With a 24ft fixed trailer, we would be in much better shape than now. The tilt just seems like a time saver. Then again I have never used one.
This type of ramp holder might sway me back to a non tilt trailer.
/ Tilt Trailers and load balance #5
I can't tell from that picture what the advantage is?
I have had them with a door that you had to swing open to pull the ramps. Then you have to lay it down to close the door before mounting the ramp. With this type of lock, you just lift it, pull the ramp, then knock it down out of the way.
/ Tilt Trailers and load balance #8
Yep, that is an advantage.
I am also looking for a tilt gooseneck, thought I had a thread on it last month, but can't find it now.
Here are some pictures the Kaufman salesman sent to me.
12-19-11 011 (Medium).jpg 12-19-11 014 (Medium).jpg 12-19-11 020 (Medium).jpg 12-19-11 028 (Medium).jpg 12-19-11 041 (Medium).jpg
Interesting they sent yellow pictures. Last time I ask, all were black from the Nebraska lot. I was considering getting one shipped, but unloading it would be the biggest hurdle for me. It's a little far for a day trip to get one too so it would cost about the same as the shipping. I have enough tractors to lift from two sides, but lack a second skilled driver. Maybe if you and I both decide to get one, we can pool resources. I'm not far from Meridian.
/ Tilt Trailers and load balance #10
Yep, I was surprised to see yellow, but it is easier to see small details of the trailer. The pictures are dated 12-19-2011, the salesman is:
Frank Allmer
Kaufman Trailers
Sales Consultant
336-790-2749 direct line
866-455-7444 toll free
336-859-5963 fax
fallmer@kaufmantrailers.com
702 North Silver St.
Lexington, NC 27292
Kaufman Trailers - Nobody sells a quality trailer for less!!!
I am looking at a red, 17,000 GVWR / 24 ft. Equipment Tilt Gooseneck Trailer - DELUXE - Kaufman Trailers , with a metal deck.
Then I found two other builders that use metal grating.
I haven't called Frank to see if they would build one with the grating deck and how heavy it would be.
Yep, even if I don't get one I will help unload yours with my V417. http://www.tractorbynet.com/forums/bobcat-construction-equipment/275747-v417-max-lift.html
/ Tilt Trailers and load balance #11
GN usually run 15-20% TW.
youll need to scale the hitch with your standard load to get an idea of were to place the tractor for the recommended TW.
those trailers usually have a curb weight of like 5K lbs so cargo on a 15K trailer is close to 13K with 3K TW.
/ Tilt Trailers and load balance #12
I really like the look of hat Kaufman trailer. That is enough of. Deck to really pile some implements.
D.
/ Tilt Trailers and load balance #13
How can it have. Pair of 8k axles but be rated for 17k?
D.
I go round and round trying to decide on one. I keep looking locally hoping to find something that would work. One concern I have with the Kaufman and others of that ilk. If you wanted to load a car, you might be in trouble. Those ramps seem a little steep.
Thanks for the offer to help unload.
D.
Yes and look at thieir 15k with dual 7k axles. Even the tire ratings don't quite add up. I think they factor in tongue weight to fudge the numbers up.
/ Tilt Trailers and load balance #16
D.
They rate the load on the hitch
I have been looking at trailers and really like the looks of the Kaufman trailers but also been looking at Econoline Trailers - Viewing 7 Ton Deck Over Multi-Purpose Tilt (16,100# GVWR) Technical Specifications
I also have gotten a quote on Maxey Trailers Mfg... We Can Do It!
which is the best looking set up I have seen so far. I am considering the Maxey with 8k axles and 17.5 wheels but I am pricing out material to build it my self also as I would rather have it set up a little different and the price is a little steep around $10k
/ Tilt Trailers and load balance #17
I want one for my next Kubota compact tractor loader. I want to load stuff on the front from the sides. Then drive the machine on with an implement.
D.
/ Tilt Trailers and load balance #20
The guy is in Nebraska. I am up there on business on occasion. I might have to go check them out.
D.
2014 Blu-Jet AT3000 Applicator (A66285)
2014 Blu-Jet...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
20x20 Car Port (A65640)
20x20 Car Port...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
Wolverine Quick Attach 84" Snow Pusher (A66285)
Wolverine Quick...
