DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,660
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
I'd find someone with a dozer comparable to like an 850 Case with a winch. Not sure what you've got to hook onto on the front of the tractor, but definitely hook to the tractor, not the loader. Lower the wings as mentioned to relieve some weight off the middle section. It should walk you right out of there.
Once the dozer is attached, and cable snug, I wouldn't be afraid to ride it out.
If it would come to that, just be sure the winch cable is in good shape, and no kinks where it could break. Where I worked, all of our dozers had winches, and they were our lifeline, so to speak , so cables were kept in good condition. Whether if it were to get ourself out, or another machine.
Are there coal mines in that area..?? Could be an old mine caving in, or an old air shaft. LOTS of these in SE Ohio..!!
