I recently purchased a 2012 X740 with the 54 inch deck, and I can tell you, the factory blades do not help.
I had a very large amount of build-up, every time I mowed. It didn't matter if it was bone dry or damp, it always collected a ton of grass. I switched to G6 gator blades, and what a difference! While there is still some build-up, it is VERY slight. I clean my deck once a month now, instead of every mowing. Everything about the G6 Gator blades is better than the OEM John Deeres, except for lift. If you want maximum suction, you need JD Hi-Lift blades. Keep in mind, the G6 blades still have very good lift.
This is one of those topics that is difficult to give advice on. Grass looks like any other grass, but it is all different. Some grass cuts really nice, and leaves little to no build-up. Some cuts horrible and piles on the clippings. Even with 2 different grass types in equal conditions of moisture content, they can cut completely different. Obviously this will affect your results.
My advice is switch to G6 Gator blades. It is as close as you will come to a clean deck without switching to a 7-Iron deck. The very design of the edge extra decks stops it from staying completely clean. The 7-Iron design is just the opposite. By design, it stays extremely clean.
