54" extra edge mower deck
/ 54" extra edge mower deck #1
orwell
orwell,ny
X748
I have to clean the under side of my deck after every mowing. Enough grass to fill 5 gal pail after mowing 1 acre. Is this a common problem with these decks ?
Yes the grass is dry when I mow. I also have the guard tied up.
/ 54" extra edge mower deck #2
Throttle wide open?
/ 54" extra edge mower deck #4
Some grass is worse about sticking than others, obviously worse when wet as you mention.
ALL grass will eventually build up under decks, but that does seem excessive to me.
Mowing at a higher level might help.
Also you might look into switching to another style of blades.
/ 54" extra edge mower deck #5
After the deck has been cleaned and then it's dry, try spraying some Fluid Film on it. It helps with my 48C Edge and a Ferris IS500Z. If nothing else it should speed up your cleanup.
I started this mowing season with clean deck, fresh JD yellow paint & a coating of Teflon lube I bought for my snowblower. Maybe this product didn't help my mower. Any suggestions on different blades ?
/ 54" extra edge mower deck #7
/ 54" extra edge mower deck #8
I don't care for the cut or air management of my earlier model 54" deck, but I must say that it got MUCH better after switching to a set of G3 Gator blades.
The Deere hi lift blades seemed to plaster the grass up on the underside.
/ 54" extra edge mower deck #9
/ 54" extra edge mower deck #10
If you aren't exaggerating about filling a 5 gallon bucket,then,yes,that is way too much grass being built up. Not sure how much difference there is with the 54" and 62" in design though.
This in my 62D before I cleaned it yesterday after cutting 4 acres of 6" tall super wet grass twice. The kind that comes out of the chute looking like you just opened a giant can of spinach.:) And yes,Gators are awesome!:thumbsup:
Greg
/ 54" extra edge mower deck #11
I recently purchased a 2012 X740 with the 54 inch deck, and I can tell you, the factory blades do not help.
I had a very large amount of build-up, every time I mowed. It didn't matter if it was bone dry or damp, it always collected a ton of grass. I switched to G6 gator blades, and what a difference! While there is still some build-up, it is VERY slight. I clean my deck once a month now, instead of every mowing. Everything about the G6 Gator blades is better than the OEM John Deeres, except for lift. If you want maximum suction, you need JD Hi-Lift blades. Keep in mind, the G6 blades still have very good lift.
This is one of those topics that is difficult to give advice on. Grass looks like any other grass, but it is all different. Some grass cuts really nice, and leaves little to no build-up. Some cuts horrible and piles on the clippings. Even with 2 different grass types in equal conditions of moisture content, they can cut completely different. Obviously this will affect your results.
My advice is switch to G6 Gator blades. It is as close as you will come to a clean deck without switching to a 7-Iron deck. The very design of the edge extra decks stops it from staying completely clean. The 7-Iron design is just the opposite. By design, it stays extremely clean.
/ 54" extra edge mower deck #12
I read all this about the G6 blades but I have never tried them.
I have no problems with the standard JD blades but I wonder what all the hoopla is about.
Are they from JD. I use the M141785 blade (3 on a 60" deck). These are about $25 each.
Do you know the G6 part number or price?
(Mine is the 755 & 445 mowers.) I am not familiar with what you call the "7-Iron deck"
/ 54" extra edge mower deck #13
I have 2 JD 445's my mother uses one with a 54" deck and it plugs up and i run a 60" deck and it plugs up too. i just painted the 60" deck and that didnt help at all. I can over fill a five gallon bucket when i cleen my deck after 3 times mowing , i am running JD ome blades. Thanks for the help.
/ 54" extra edge mower deck #14
The G3 and G5 are plenty adequate. The G6's are huge. I have a set for my 7 Iron, but hav eyet to use them. The 7I with Hi lift works exceptionally well, but as with any OE blades, the tips wear to rounded ends quickly.
/ 54" extra edge mower deck #15
The hoopla is how clean they keep your deck. Did you see my previous post? Those are G6's.
No,they are not JD. They are made by Oregon.The chainsaw chain people.
7 Iron is basically a commercial deck that JD offers mostly for their zero turns. I think (not positive) you can get it with some JD garden tractor models also.
This is one example of price. There are many more to be found online also.
Oregon 20-1/2" Gator Mulcher G6 Mower Blade (29/32" Center Hole) For John Deere (M48452, M112847, Am35557, Am100538, M87622, M141785) | 20 Thru 23 Inch | John Deere | www.baileysonline.com
Greg
/ 54" extra edge mower deck #16
That is a cheap price.. I've been seeing 2x or more that.
/ 54" extra edge mower deck #17
Don't be fooled by thinking "a blade is a blade"
Blades have a HUGE affect on how the air flows underneath your deck. Changing the way the air moves can drastically reduce the amount of grass build-up. John Deere OEM blades tend to push grass clippings vertical into the top face of the deck. Build-up starts fast.
G6 Gator blades recirculate clippings, they stop them from being shoved up to the top of the deck. Clippings make a circular motion and are re-cut by the blade edge multiple times before exiting the side discharge opening.
The other downside to your situation is you are running the oldest version of the 54'' edge deck. The first versions have a different stamping design, and are not very good at staying clean. The latest version is a much better design, but still no 7-Iron.
/ 54" extra edge mower deck #18
Thanks, and this is just really interesting. They are actually cheaper that the standard blades I have been getting from JD.
BUT my concern is rocks. I am all for keeping the deck cleaner because this is a problem for me.
I mow about 4 acres a week and some areas have bare/dry sections with small rocks and then driveway edges that have larger rocks.
In the past I have had problems with "mulch" style blades that suck up more rocks than grass it seems.
I wonder if I might need to try a set of the G6's.
I don't care so much for the "recut" business, I just want the grass to go OUT The chute.
Maybe I am in the wrong thread here which is about the "Edge 54" deck.
My 755 & 445 uses the Commercial 60" deck.
/ 54" extra edge mower deck #19
Have the 54HC. I Have adjusted leveling points using manuals specifications. Using the deck location and using the blades from sides and middle front. Have depth gauge at 3 inches. Front middle blade at 2 3/4 inch. My problem is the deck seems to cut a deeper blade cut on right side. See pictures. I cannot correct this. What causes this. Blades, deck? 16 hrs on deck and tractor. Any you folks have any idea please let me know. IMAG0418.jpg
/ 54" extra edge mower deck #20
Have the 54HC. I Have adjusted leveling points using manuals specifications. Using the deck location and using the blades from sides and middle front. Have depth gauge at 3 inches. Front middle blade at 2 3/4 inch. My problem is the deck seems to cut a deeper blade cut on right side. See pictures. I cannot correct this. What causes this. Blades, deck? 16 hrs on deck and tractor. Any you folks have any idea please let me know. View attachment 332114
Check your tire pressures. Even a few pounds off can lower one side.
If you have checked everything, one of your lift arms could be lower than the other.
Skid Mounted Long Sprayer (A61166)
Skid Mounted Long...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A62130)
2008 INTERNATIONAL...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61567)
2019 Toro...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
20ft Shipping Container (A61166)
20ft Shipping...
2016 JCB 510-56 10000 LB Telehandler (A64047)
2016 JCB 510-56...
