Comparison Max series Tractors
/ Max series Tractors #1
NE Tractor
Hampton NH
case
OK so I'm going to say something that will probably offend the Mahindra loyal, but here goes. I have looked extensively at these tractors, talked to several dealers and have come to the conclusion that this is a grand marketing scheme. The premise that this is a whole new line of tractors with great innovation is to me, a load of bunk. I look at a 1998 Mitsu/Cub tractor and there is nothing but a sheet metal change and very little else. Don't get me wrong the little Mitsubishi tractors are great little tractors but hardly cutting edge. What is worse is Mahindra's decision to go with KMW loaders. There are no steel tubes on the Max 22 and 25 loaders, just a spaghetti of hydraulic hoses. There are also no gussets on any of the pivot pins on the Max 22 and 25 only the Korean made loaders on the Max 28 have steel tubing and gussets on the pivot pins.
I guess I'm just severely dissapointed to see Mahindra doing business like Bose, with lots of marketing and very little substance to back it up. As a second I'd like to stress my disappointment in KMW, an American made loader should be better in every way not good enough or inferior to others... no wonder we are hemorrhaging jobs to Asia.
I have talked to at least 7 Mahindra dealers and was told by most of them that Mahindra hired a high ranking person from each of the major Manufacturers Kubota, Deere, New Holland (LS) and Agco (Massey/Iseki) ( Mahindra and the last two in the size category I'm speaking of are rebranders, not really manufacturer's) and spent a ton of money on research for these tractors. My guess is that they are all marketing guys and they have created a slick configuration software program to market the tractors but have spent very little dollars on making a great innovative tractor.
Will this strategy work? Maybe, but not on me... Until Mahindra shows me otherwise I see that Kubota and Deere have NOTHING to worry about.
Love them or hate them I see Deere as a great innovator, their stuff is wayyyyy overpriced but they have a lot of great ideas. Kubota is stingy with features but pretty bullet proof and its no wonder they are Number 1(for new) and 2 (For used) in sales in the US. I like a lot about the Kioti's but keep getting mixed messages about their reliability from their dealers.
/ Max series Tractors #2
Hi NE Tractor, welcome to TBN. It's a little odd to have just a handful of posts and then step into the Mahindra community with a bunch of half truths. Sort of like a Giants fan walking into the Dodger's dugout and giving them heck....but I guess that is your choice. :rolleyes:
We have been expanding in the NE and have had months upon months of record sales, so I guess we should expect some pushback. And that is OK. Regarding our marketing team, it is robust and active, and they push our strong points, like the 30 day money back Max deal, the 5 year warranty, the huge lift capacities, the tight turning radius, the full frame, the bigger tires...yep, the marketing team is doing a great job. You are aware that worldwide Mahindra sells more tractors than any other brand, and I do believe that Mahindra is now #3 in the USA in the <80hp tractor market? Marketing has been part of that.
As for half truths, it is true that some early Mitsu based Mahindra tractors were nearly identical to some of the Cub models. I think the 2615 had a twin, as did the 2015. Of course different loaders, tires, seats, etc., but the basic tractor was the same. It is not true that the current ones resemble or are even close to the older Cubs. Not that it was bad in the first place, the Mitsu-Cubs were great, but the Max models are very different. They are built in Japan by Mitsubishi, so that part of your "truth" is correct. Are they a little heavy duty to be called SCUTs? That has been debated to death, and we say no, this is what a SCUT should be. I can understand that since we have no clear definition of SCUT that we can argue forever on this point. But the argument that it is marketing without substance does not fly since our marketing is full of substance. We do not hide that our Max tractors are a little stronger and heavier, we brag about it. It is very clear to the customer, and sales have been brisk.
As for KMW using hoses, that is good and bad. I too prefer steel lines with minimal hoses, but it does create more connections, and connections are where leaks occur most. Also, a hose can be bought at any hydraulic shop in any town, if you crush a steel tube you are generally at the dealer and most dealers do not stock extra loader tubes. So there is a trade off on tube vs hose. What I really appreciate about KMW is the design and testing that they do. When they design a loader system, they install it on a tractor and hydraulically abuse the system until something breaks, be it the tractor or the loader. Then they re-evaluate and redesign and go at it again until they are satisfied in the design, considering of course duty cycle, max load, etc. They aren't perfect, but they are pretty impressive.
As far as re-branders, we confess that the Max and 16 series are built by Mitsubishi in Japan. We do that at great expense. If you look at worldwide numbers for Mahindra, which I believe to be over 200k units annually, it is a small portion that Mahindra does not build. The "rebrand" percentage is higher in the USA due to the market for CUTs and SCUTs which really aren't such a big deal in most of the world. John Deere, NH, Massey and others have rebranded tens of thousands if not hundreds of thousands of Japanese tractors over the years. It's a great way (other than expensive) to get a top quality compact tractor, while allowing the core production line to keep cranking out the larger units.
As far as Deere and Kubota having nothing to worry about...it is true that the gap between 2nd and 3rd place for tractor sales in the USA is large. It's like a runner in a race where JD and Kubota are neck and neck at the finish line, then there is a gap and we see Mahindra with a bunch of other brands close behind. So as far as USA market share, it is Mahindra's hope that JD and Kubota will just be comfortable where they are and ignore Mahindra...nothing to worry about...just ignore us please.
:dance1:
/ Max series Tractors #3
I don't put much stock in someone who starts a post that he is going to make people mad but he's going to say it anyway. There is a word for that and it's troll.
Call it what you will, I apologize I should have said It was not an attack on Mahindra buyers. I was just making an observation not trying to tick anyone off it was more an assessment of Mahindra and what I feel is more marketing and less of a commitment to quality. If I can provoke someone to make or do something better, I'm going to do it. If you can tell me, show me where my assessments were wrong, My ears and eyes are open.
:dance1:
Dave, I appreciate your defense of Mahindra But you can correct me if I'm wrong ( if you have the New England sales numbers) but in the north east I travel daily through all the New England states, I see the same tractors on the Dealers lots here till they are sun bleached pink. I see nothing leaving the lot from the dealer close to my house in New Hampshire that I drive by every day. I got a quote on a Max 28XL from four different dealers here and they were all over 15,500 Tractor Loader (which is why I made the statement Kubota and Deere have nothing to worry about) Here you can buy a Kubota 2920 for the same price and it has in my opinion what seems to be a better loader, but as I said the 28's loader is much more impressive looking, it was the KMW's I had issue with... I could easily move the pivot pins and feel slop on the 22 and 25's loaders. I just cant see how not having gussets welded around the pivot pin stress points speaks anything to KMW's commitment to quality.
As I stated I think the Mitsubishi tractors are great, I despise the treadle pedal they use on their hydro(its the same one from 1998) and thats something I would have expected Mahindra to upgrade if they are truly trying to build a better tractor. I want Mahindra to succeed, I hope they come up with innovations to improve the tractor market place. I want them to provoke Kubota and Deere, it will be better for all of us. I can't speak for other parts of the country, but Kioti in New England has done wonders, I believe Kioti is trying to give people more for their dollar. I was disappointed mostly when I looked at the Max 28, I love the size and wanted to love the tractor, but at 15,500.00 the fact that it has no suspension seat (even the Kioti CK20 at 12,000.00 has one) I find to be unfortunate. I believe the Mitsubishi tractor is a great foundation, I just feel building on it with KMW is a bad decision. I have had a 1968 580CK case backhoe for 32 years, with over 10000 hours, never a bent tube, they are all original, but countless blown hydraulic hoses. so forgive me if I'm not seeing the plus side to all hoses.
Steve
/ Max series Tractors #6
Because your main issue seems to be with the KMW loaders, let me say: My 2615 Mahindra with a 106 KMW loader has almost 600 hrs of use. Conservatively, over half those hours were racked up with the use of the loader. I've checked every pivot pin. Not one of them had a bit of slop. There are no cracks or signs of stress to be seen anywhere you look.
What we have here is either a John Deere, or a Kubota dealer who is dyed in the wool.
/ Max series Tractors #7
yep, been selling them for 7 years he says.
I have never sold Kubota tractors or John Deere I sold Massey Ferguson and Kioti tractors So you would both be incorrect. I have my issues with both Massey and Kioti. But would post those issues in those forums. My main issue with Mahindra was that they were pitching the Max series as something new and different and I feel its more the same than different....and again it's an OPINION
/ Max series Tractors #9
I said selling I did not say a brand.. I like a lot about the Kioti's but keep getting mixed messages about their reliability from their Dealers?
Whats that about? You were the dealer. Who you giving mixed messages too?
Not dyed in the wool at all never sold either one, I've just operated several tractors over the years, sold Masseys and Kioti's for a few years...and have seen a lot of good and a lot of bad. When I see a trend that I don't like I'm going to speak up about it, if you don't like it...well I'm sorry it's my opinion and nothing more. I thought that's what this place was about, the sharing of ideas and calling a foul when you see one.
Let me ask you a question... If McDonald's cut the meat content in their patties and put sawdust instead of meat in their burgers... then ran a huge add campaign telling you it was a Better Burger, would you not say a word and just eat what they fed you?
I'm a consumer just like you and when I see someone cheapening a product and then calling it better, I for one am going to stand up and say NOT!
Just to clarify I said the Mitsubishi tractor was a great foundation, and yes my issue is with the KMW loader that Mahindra chose ... NOT the ML106, it's a completely different loader. Your loader has gussets on all the pivot pins and steel hydraulic lines. The 202 loader on the MAX 22 and 25 don't have steel lines , nor do they have gussets on any of the pivot pins, its just a hole punched in the loader frame (if you look at the pivot pins you can see daylight all around where they are supposed to be supported) again the 202 is nothing like your ML 106 .... I also said the loader on the 28 was better, it has steel lines and gussets on the pivot pins (but the dealer told me that loader (made in Korea) was going away in favor of the chintzier (his words not mine) KMW loader.
I sold Kioti's from 2002-2005, Masseys from 2002 to 2009 so I'm speaking of current models and the feedback I have gotten from guys I know in the business
In the quote you are referring to I used the words I sold tractors, as in past tense, I never used the words I sell them.
/ Max series Tractors #13
I have had my Max 22 for one year, and granted, I only have 98 hours on it but I can tell you I have no daylight or slop in my pivot pins which I inspect regularly because of my lack of knowledge in how these stress points wear. Other than mowing for a total of 8 hours and snow blowing for a total of 10 hours all my hours have been spent using the loader, so figure 80 hours of loader work. I've posted a few videos of the loader capacity and the abuse it has endured, so it is not like I am only loading a few buckets of sand.
As far as re branding and no difference that also is not true, although the tractors are similar in many ways. I live in Maine and there are two dealers in the Southern part. Both are doing quite well and I have yet to see any pink tractors, but have seen quite a few pink implements. Maybe New Hampshire businesses enjoy being in business just for the sake of it. Seems like a bad business model to me, but hey, I am just a small business owner myself who does it to make money, not as a hobby.
/ Max series Tractors #14
Steve
Steve,
You suggested I can correct you if you are wrong, and I appreciate that. For 2013, January through July, Mahindra Max sales are up 158% in the northeast. The tractor market in general in that area is up about 10%, so we are outpacing that gain by a multiple of 15. In any area, I suppose there are dealers doing great, and some that can't sell ice cream for free on a hot day. By and large, our dealers are doing great in the NE.
I can't comment on price as every dealer can price as he sees fit. Obviously a Japanese built tractor is not going to be cheap, regardless of branding. I suspect an aggressive Kubota dealer can beat a high margin Mahindra dealer on price, but the opposite is true as well. And of course doing an apples to apples comparison is very difficult.
You despise the treadle pedal, and I prefer it. I don't like the side by side pedal, and you do. Fair enough. (It isn't actually the same pedal nor is it the same HST unit, but it is similar and I will grant that was your meaning.) You could also say you prefer orange and Mahindra should have "upgraded" to orange paint and you despise the red and see that as a failure. Well, I like red. And we do not expect everyone to prefer Mahindra. Just like Chevy and Ford, it is good we have options. If you like a side by side pedal, the Max is not for you.
I respect Kioti. You won't find me beating up on them. They seem to make a solid tractor and I have wondered why they do not have more market share. I like Kubota as well, and certainly respect their market share and concern for quality. And who does not like JD? I own an old JD 420 crawler and it is cool. So I am a Mahindra dealer and Mahindra fan, but not blindly so.
I also have a track loader at home, a Takeuchi TL130. All the (huge) pins have bushings, the lines are all steel with minimal hose, it is overbuilt every where and I really like it. It is a construction rig that can be used like it was stolen for 8 hours a day, 7 days a week. I don't expect a SCUT or a CUT to be built like that. And it would be too heavy if it were. While I too like big pins and bushings and hard lines, I can more appreciate a well designed, well balanced, well tested approach to give us quality without overkill. You can recall that there were serious issues with a particular tractor brand (not Mahindra) a few years ago with the loaders cracking on the cross tube that connected the 2 loader arms due to poor design or materials. They may have had bushings and hard lines, but were failing at a huge rate. So while what you say has some merit, we appreciate KMW and feel they build a nice loader. It is always a balance between features, specs, duty cycle design and price.
/ Max series Tractors #15
Very well put dave...:thumbsup:
/ Max series Tractors #16
Dave, is so good at putting thoughts into words. I would like to have a bit of his gift for words.
/ Max series Tractors #17
You and me both, Galen..
/ Max series Tractors #18
And???
/ Max series Tractors #19
I got more tractor for less money out of my max28 vs the local deere and bota dealers' lesser models.. I could have spent a couple more K and gotten a bx25, and I highly doubt the 'technology' on that tractor is vastly different than the 'technology' on the max. I just got more power, better ground clearance, and it's not f-ing orange. (I hate the color orange. While that wasn't a huge influence on my tractor purchase, the kubota dealers I called being dicks in addition to having higher prices was. Ending up with a red tractor was just icing on the cake) Deere was also just too rich for my blood. I like their stuff, I love my 717a ztr, it's a champion, but their stuff ain't cheap by any stretch.
OP sounds more butthurt and excuse-ridden hence the attempt at disparagement, and I concur with the others, obvious troll is obvious.
/ Max series Tractors #20
Just took delivery of a Max25 TLB with MMM 3 hours ago. Researched everything since March and concluded that it was the most tractor for the money. I don't care about cup holders and refinements, performance trumps all. Did I make the right choice? Time will tell.
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2020 Toro...
Lesco 50Lb Push Spreader (A64557)
Lesco 50Lb Push...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
1995 NAVISTAR INTERNATIONAL 4700 S/A FUEL TRUCK (A65054)
1995 NAVISTAR...
REDDICK OFFSET DITCHER, 3PT (A64278)
REDDICK OFFSET...
2012 Ford E-350 Cargo Van (A64556)
2012 Ford E-350...
