Crawler Final Drive Service
/ Crawler Final Drive Service #1
nmitch1
Redding, CA
Ford
Hello TBN users! My first post here just a simple double check on my maintenance procedure. We recently picked up a small crawler for our vineyard and I have been trying to familiarize myself with all of the routine maintenance.
My question is the proper fill and check of the oil in the rear final drives. There are three plugs one on the top of the drive, one half way down (picture behind bracket) and the drain on the bottom. Are the drives filled with oil till it runs out of the middle plug on the back of the drive or is it filled to touch from the top plug?
Thanks
Nick
/ Crawler Final Drive Service #2
What kind of crawler are we working on here?:confused3:
/ Crawler Final Drive Service #3
The finals I have experience with are filled about half way, but you really need to find out for sure on your articular machine. Depending on the reduction ratio in the drive, the input gears can be spinning very fast and heat buildup is a concern. Unlikely proper fill would be almost completely full leaving no room for expansion.
thank you MharryE. It is a Landini crawler. I assumed that was the correct fill/check but the service manual that I have did not state fill volume or correct method to check the level.
/ Crawler Final Drive Service #5
That's the kind of useful information found in an operator's manual.
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2006 Volvo VNM S/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM S/A...
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
