Replacement Directional Control Valve
   / Replacement Directional Control Valve #1
Fergy
Member
alexandria, ontario
Massey Ferguson 50c
I own a Massey Ferguson 50c tractor. My directional control valve for the rear remotes is leaking, also I find that one of the spools binds when pushed in. The valve is made by Gresen, though the model number is illegible. My hydraulics is rated at 29GPM. What would be a goood relpacement valve for my tractor. My primary use for the valves right now is chute control (a motor and a piston) on my snowblower, although there will be other implements I may attach in the future. Thank you.
   / Replacement Directional Control Valve #2
If you look at stacked valves, you can tailor the spools to suit your needs..
Surplus Center
Thanks JJ. Could you please elaborate on the advantages of stacked valves?
   / Replacement Directional Control Valve #4
By using stacked valves, you can select what each spool is going to do. You can add a motor spool, 3way detent, SA cyl. Each spool can be selected for a particular function. They can get expensive, but you get what you want.
If you need a four spool valve, you select the end units which hold the valve together and select from the list exactly what you want in a valve. and then you need the bolts to connect all the spools and end sections.
You can change things later if you need something different.
Wow!! Thats something that I might be interested in, thanks JJ, I appreciate it.
I'm reviving this old thread, as I have finally decided to take the plunge.
I have decided on a Parker V20 sectional valve with Power Beyond.
I am purchasing 2 sections, (for now), one with a float position.
Before I proceed with my purchase ..........
Any comments on my choice?
   / Replacement Directional Control Valve #7
Massey Ferguson 50c
Hydraulics:
Type: gear pump
Capacity: 7 gal [26.5 L] (reservoir)
10 gal [37.9 L] (loader)
15 gal [56.8 L] (backhoe)
Pressure: 2000 psi [137.9 bar]
Total flow: 29 gpm [109.8 lpm]
Steering cap.: 2 qts [1.9 L]
You mentioned hyd for a motor and cyl awhile back.
Yes JJ, the motor is for the chute rotator, and the cylinder is for the chute deflector.
I'm thinking of changing my hydraulic fluid and filter, while I'm at it, along with any hoses and fittings that may need replacing.
Although I generally use Parker products, is there any place beside the MF dealer that I can purchase hose and fittings for my 35 year old machine. Thank you for your input.
Thanks JJ.
Got down to work last weekend. Drained my hydraulic fluid, removed the filter, and suction filter, and pulled out the old directional valve.
As you can see I have to change quite a few hoses and fittings to change.
Already I see a problem, I notice there is a JIC SAE14 fitting going from the loader valve to the remote directional valve.
I'm looking at Parker fittings but I don't see many with a SAE14 end.
What I'm looking for is a SAE14 jic female swivel, connected to a 1 inch (-16) hose.
Do you see any other options?? :confused3:
   / Replacement Directional Control Valve #11
I would not reuse those water pipe fittings, use only hyd fittings.
:laughing: I didn't realize those were water pipe fittings. Thankfully, my new valve that I ordered has orb ports.
   / Replacement Directional Control Valve #13
Older equipment w/ "pipe fittings" usually ended up w/ black pipe. It was quick and easy for owners. Not good, but they did it. For "low" pressure open center systems....it worked for them. It was easier, faster and cheaper to go to the hardware and get black pipe then go to the dealer and buy hydraulic fittings (that were pipe thread). LOL, some dealers stocked black pipe and would sell that....
Well I'm trying as much as I can to stay away from pipe fittings. It's ORB to JIC on my new valve, and my QC's have 1/2" pipe female, which I will adapt to JIC.
JIC14 fittings seem very rare. Having a hard time to find a replacement. Any ideas?
   / Replacement Directional Control Valve #16
Does Surplus Center or that other hydraulic link stick have it? If not, a local hydraulic store should be able to get what you need. Don't go to an equipment dealer, but someone store that deals w/ hydraulics. We have one in my town....you an get just about anything there.
Thanks Kaliburz, i ordered what I needed from Parker. My parts should be in this week then hopefully this weekend I will proceed. Will be sure to post pics of my ordeal. Lol
I picked up my parts, and got to work this weekend.Boxed.jpgPre assembly.jpg
Left Cover, Float section, 4-way 3-pos section, Right cover w/PB, Adjustable Relief, PB sleeve and Handles.
My budget allowed for only 2 work sections (for now).
followed by painting MF Industrial yellow.Painted1.jpgPainted2.jpgPainted3.jpg
Next weekend I shall install this baby on the tractor.
   / Replacement Directional Control Valve #19
Did you torque the connecting rods as they directed?
Do not tighten the valve to the frame to tight.
I torqued the studs at 25 ft lbs, figured I could always tighten a bit more if I ran into problems.
I will tighten about the same when I attach the valve to the tractor.
Towable Centrifugal Water Pump (A59228)
Towable...
Great Dane Van Trailer 1989 (A56438)
Great Dane Van...
2022 CATERILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERILLAR...
2019 GALYEAN...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
