I would say modern diesels today, never.
Old or new when they get an unlimited fuel supply through the air inlet they will just keep on revving up.
In most cases the same Diesel engine only runs away once!:thumbsup:
Diesel Engine Air Intake Shutoff Valves
Model RDS5 High Temperature Electric Swing Gate Valve
Overview
If flammable gas or vapor is present in the atmosphere surrounding a diesel engine, it can be ingested into the engine and become an ungoverned fuel supply. This ungoverned fuel can result in runaway engine overspeed, potentially leading to dangerous mechanical failure or an explosion.
The Roda Deaco RDS5 Swing Gate Valve is a positive spring actuated air intake shutoff valve that provides emergency overspeed shutdown of a diesel engine. The RDS5 Swing Gate Valve can be triggered to close, which starves the engine of air and shuts down the engine.
Model RDS5
High Temperature Electric Valve
Reliable protection from
diesel engine overspeed
During operation of industrial and marine engines, combustible vapors present in the operating envelope of the engine can be drawn into the air intake. This provides an additional source of fuel. Intake of this va- por can result in loss of engine control. Loss of control can also be the result of a failed drive train or sudden loss of a coupled load. Attempts to shutdown the engine by standard control systems such as normal fuel shutoff will not stop the runaway condition and prevent serious engine damage, personal injury or catastrophic results.
