Mahindra rotary mower ......
/ Mahindra rotary mower ...... #1
67PLY
PENNSYLVANIA
MASSEY GC2310
Any thoughts on the Mahindra 5 foot - 3 point hitch rotary mower ? - looked a one on Sunday at local dealer.
/ Mahindra rotary mower ...... #2
The one they sold me for my 4035HST came with a Mahindra Max sticker on the side was actually made by Kodiak for Mahindra. It seems to be a good product.
Thanks - the one I looked at said SD or ST 60 Mahindra MAX - do you recall the $$$ ... ?
/ Mahindra rotary mower ...... #4
I have a 6 foot Mahindra SD (standard duty) made buy Kodiak and have not had any issues with it. I paid $1350.00 for it last April.
The 5 foot SD model I looked on Monday sells for $ 1150.00 - really fair price. Looks like the back is open ... rear discharge like our old woods mower. Our tractor is around 28 hp - not sure if it could pull a 6 fioot in high grass. Thanks for your input.
/ Mahindra rotary mower ...... #6
I have a Kodiak HD8. It's been great for the 2.5 years I have had it. Seems well built.
/ Mahindra rotary mower ...... #7
I have a Max 25. It easily handled a 5 ft rear mount bush hog. It also has a 5 ft mid mount mower and I have only once choked it out that I've killed the engine. A rear mount mount runs at lower RPMs. I don't think a 6 ft would be a problem.
The next question to ask is "Does the extra foot make a difference in getting the job done for the money?"
/ Mahindra rotary mower ...... #8
Short answer, yes.
Long answer is to calculate the time exactly. How many passes with your 5 foot mower does it take to mow your area? How long does it take to make a single pass? How many passes are you going to save? That's how much time you can save.
Another way to look at it is for every 5 passes with a 6 foot mower, you've covered as much ground as 6 passes with a 5 foot mower.
Another consideration is maneuverability. Is there anyplace that is a tight fit with the 5 foot mower? A 6 foot would surely fit tighter.
/ Mahindra rotary mower ...... #9
I'm not disagreeing with you. I'm just pointing out whether is the extra $2-400 really worth it.
In my case the I'm finish mowing about 2 acres every week, and making a pass on the other 2 acres about every two-three weeks. The extra foot would probably save me about 15 minutes, maybe 30. Not a significant enough difference to me for the dollars. So I have to wait a little longer to put my steak on the grill. If it were 8-10 acres then I would probably cough for it. If I were doing 40 acres, I would go to the bat wing type mower that they use alongside the highway.
Again, it is what you value and where you're using it. :confused3:
/ Mahindra rotary mower ...... #10
Hi 67PLY,
I have a Kodiak "Mahindra" stickered standard duty 5 foot rotary cutter with a slip clutch. I have had it for a little over a year and I have been very pleased with it. I have taken on more than what it is rated for and it is holding up very well. I looked at many different brands and I felt for the money this was one of the better built cutters.
My tractor has approximately 23hp at the PTO. Quite low, but it handles the 5 footer well. Tall grass can bog the tractor a bit, but anything else is no match. I think a 6 footer might be a bit much for your tractor.
Tax included, I paid $990 for the 5' with a slip clutch. I don't think you will be disappointed. My buddy just bought a 7' HD version and wow! Built twice as tough as a tank.
/ Mahindra rotary mower ...... #11
Here's mine in action on my 4035HST.
VIDEO
Pallet of Fork and Frame Mini Skid Steer Attachment (A61567)
Pallet of Fork and...
2016 Nissan Altima Passenger Sedan (A61569)
2016 Nissan Altima...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
Holland Tandem Axle Rear Truck Frame (A61568)
Holland Tandem...
(2) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(2) 380/85R28...
2015 JLG M600JP TELESCOPIC BOOM LIFT (A62129)
2015 JLG M600JP...
