Mahindra rotary mower ......
/ Mahindra rotary mower ...... #1
67PLY
PENNSYLVANIA
MASSEY GC2310
Any thoughts on the Mahindra 5 foot - 3 point hitch rotary mower ? - looked a one on Sunday at local dealer.
/ Mahindra rotary mower ...... #2
The one they sold me for my 4035HST came with a Mahindra Max sticker on the side was actually made by Kodiak for Mahindra. It seems to be a good product.
Thanks - the one I looked at said SD or ST 60 Mahindra MAX - do you recall the $$$ ... ?
/ Mahindra rotary mower ...... #4
I have a 6 foot Mahindra SD (standard duty) made buy Kodiak and have not had any issues with it. I paid $1350.00 for it last April.
The 5 foot SD model I looked on Monday sells for $ 1150.00 - really fair price. Looks like the back is open ... rear discharge like our old woods mower. Our tractor is around 28 hp - not sure if it could pull a 6 fioot in high grass. Thanks for your input.
/ Mahindra rotary mower ...... #6
I have a Kodiak HD8. It's been great for the 2.5 years I have had it. Seems well built.
/ Mahindra rotary mower ...... #7
I have a Max 25. It easily handled a 5 ft rear mount bush hog. It also has a 5 ft mid mount mower and I have only once choked it out that I've killed the engine. A rear mount mount runs at lower RPMs. I don't think a 6 ft would be a problem.
The next question to ask is "Does the extra foot make a difference in getting the job done for the money?"
/ Mahindra rotary mower ...... #8
Short answer, yes.
Long answer is to calculate the time exactly. How many passes with your 5 foot mower does it take to mow your area? How long does it take to make a single pass? How many passes are you going to save? That's how much time you can save.
Another way to look at it is for every 5 passes with a 6 foot mower, you've covered as much ground as 6 passes with a 5 foot mower.
Another consideration is maneuverability. Is there anyplace that is a tight fit with the 5 foot mower? A 6 foot would surely fit tighter.
/ Mahindra rotary mower ...... #9
I'm not disagreeing with you. I'm just pointing out whether is the extra $2-400 really worth it.
In my case the I'm finish mowing about 2 acres every week, and making a pass on the other 2 acres about every two-three weeks. The extra foot would probably save me about 15 minutes, maybe 30. Not a significant enough difference to me for the dollars. So I have to wait a little longer to put my steak on the grill. If it were 8-10 acres then I would probably cough for it. If I were doing 40 acres, I would go to the bat wing type mower that they use alongside the highway.
Again, it is what you value and where you're using it. :confused3:
/ Mahindra rotary mower ...... #10
Hi 67PLY,
I have a Kodiak "Mahindra" stickered standard duty 5 foot rotary cutter with a slip clutch. I have had it for a little over a year and I have been very pleased with it. I have taken on more than what it is rated for and it is holding up very well. I looked at many different brands and I felt for the money this was one of the better built cutters.
My tractor has approximately 23hp at the PTO. Quite low, but it handles the 5 footer well. Tall grass can bog the tractor a bit, but anything else is no match. I think a 6 footer might be a bit much for your tractor.
Tax included, I paid $990 for the 5' with a slip clutch. I don't think you will be disappointed. My buddy just bought a 7' HD version and wow! Built twice as tough as a tank.
/ Mahindra rotary mower ...... #11
Here's mine in action on my 4035HST.
VIDEO
AGT LRT23 (A64912)
AGT LRT23 (A64912)
2013 John Deere 544K Articulated Wheel Loader (A66734)
2013 John Deere...
2025 Kioti CS2530 - like new!
2025 Kioti CS2530...
2004 Freightliner FL70 Water Truck (A68183)
2004 Freightliner...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
