Mahindra vs Kubota
/ Mahindra vs Kubota #41
My Kubota 4240 came with tubes in the rear tires so any fluid can be used. Not sure if the MX is the same or not. Congrats. The 5100 is a nice workhorse.
/ Mahindra vs Kubota #42
You still do not want to use calcium. If the valve stem leaks it will eat the wheel up.
/ Mahindra vs Kubota #43
Calcium is cheaper, so they may use it if you don't ask. Many dealers still use calcium because they have used it for years and have all of the equipment to use it, but it is nasty when you get a leak. Rust rust rust. Rim Guard is actually a beet juice product that is totally biodegradable so a spill isn't a worry.
They are using the beet juice.
/ Mahindra vs Kubota #45
The pictures you see of wheels rotted out with holes in them are from tubed tires, filled with calcium and a slow leak in the tube, or one that was pumped out and repaired and put back together without being cleaned out. The area between the tube and wheel is a perfect environment for rot, with even just plain water.
/ Mahindra vs Kubota #46
Like these wheels
/ Mahindra vs Kubota #47
Enjoy that new tractor feel!!!!
/ Mahindra vs Kubota #48
Congrats on the new tractor. Are you getting the standard bucket in addition to the larger one. I think you will really enjoy the 5100, it is basically the same as my 5240 and I love it.
Just getting the larger bucket. It is still a general purpose bucket just bigger and heavier. One bucket is enough.
Planning on getting a finishing mower for the back of it. A Phoenix 7 footer from Everything Attachments. Any better choices for the price? I have their brand rototiller and I like it.
/ Mahindra vs Kubota #50
I have an Edge attachments 72" finish mower and I have been pretty happy with it. The reason I bought it though is because it is what my dealer carries not that it is necessarily better than any other.
/ Mahindra vs Kubota #51
If you have a leak you need to repair it otherwise you will have bigger issues, like one tire weighing more than the other to deal with. But, yes, if you have a hole in your tube it can leak and corrode your steel wheel. Since corl is getting Rim Guard he has nothing to worry about. Unless, of course, he gets a leak. :laughing:
/ Mahindra vs Kubota #52
/ Mahindra vs Kubota #53
It odes not take very much of a leak to cause rust with CaCl.
/ Mahindra vs Kubota #54
You are both correct.
It's all about taking care of your equipment.
If folks would have there tires properly fixed at the first sign of trouble, then these corrosion issues are much less a problem.
Well the tractor got delivered yesterday and has already tilled part of the garden. The tires are tubeless and the fluid is M100/ not beet juice.
/ Mahindra vs Kubota #56
Congrats, enjoy your new tractor.
/ Mahindra vs Kubota #57
Nice! That bucket looks huge on that tractor.
/ Mahindra vs Kubota #59
I really like those 5100's
That is a lot of power for physical size. Never had one but would be proud to have one, congratulations!
The bucket is only 72 inches wide. The camera angle does make it look big. It is .78 cubic yards stacked so it is bigger than the .48 cu yd bucket that would normally come with the tractor.
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
61" UNDER CUTTER (A63290)
61" UNDER CUTTER...
Gradall no crank no start (A61568)
Gradall no crank...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
