Buying Advice which tractor to buy?
/ which tractor to buy? #1
chad26
eau claire,wi
none yet
I'm thinking of buying a B2920 or B3200. I have 240 acres of hunting land that has 15 acre of field to plant 5acres of corn and 5acres of soybeans and about 2acres of food plots. There is about 2 to 3 miles of logging roads to up keep with brush cutting and fix some of the down hills do to ruts from the rain.I've driven the B2920 but not the B3200. The B2920 feels good and the price is what I'm looking to spend. But not sure it will do for what I want and need to do.
Attachments that I will be purchasing is has follows.
Front end loader with the tractor
60 inch brush hog
60 inch box blade
60 inch tiller or disk harrow
I have the use of a two row corn planter also
I like the bigger foot print on the 3200 length and width for pulling power , but the 2920 for the lower center of gravity. I'm leaning towards the 2920, but not sure if it will do all the work I want it to do. I know the 3200 would work but would I really need the extra power? I like the maneuverability of the 2920.
Any experience or recommendations would be greatly appreciated!
Don't want to spend the extra cost, but want to buy the correct one the first time.
My dealer says I would be happy with the 2920.
Thanks
Chad
/ which tractor to buy? #2
Both seem awfully small for that much land, and those tasks. I'd be in a world of hurt, and I have a fraction of what you're talking about.
/ which tractor to buy? #3
1st Welcome to TBN. I agree with Gman That is way too small for what your doing. You need something to work with 6 ft implements. 40 or so hp.and heavy
/ which tractor to buy? #4
I'm going to go against the grain here. It sounds like you are only maintaining 15 of the 240 acres, and you have listed 5' implements, not 6' implements. With that said, of the two you mentioned, I would probably go with the larger B3200 to have a little bit extra in reserve. I don't think you would need a 40+HP tractor for what you are doing.
I'm no expert, though.
/ which tractor to buy? #5
Neither would be my choice as I hate quarter inching 3PH, but that's not what you asked. Of the two I would go with the 3200 and put some wheel spacers on it.
I shopped for these tractors several years ago and decided against them, but lots of people like them. Some report vibration in the 3200, so I would check it out at 540 PTO power.
/ which tractor to buy? #7
I'm thinking of buying a B2920 or B3200. I have 240 acres of hunting land that has 15 acre of field to plant 5acres of corn and 5acres of soybeans and about 2acres of food plots. There is about 2 to 3 miles of logging roads to up keep with brush cutting and fix some of the down hills do to ruts from the rain.I've driven the B2920 but not the B3200. But not sure it will do for what I want and need to do.
I like the bigger foot print on the 3200 length and width for pulling power , but the 2920 for the lower center of gravity. I know the 3200 would work but would I really need the extra power? I like the maneuverability of the 2920.
Look at the Kubota B3300SU tractor/loader PACKAGE. The tractor is either the same or VERY SIMILAR to B3200, however Kubota packages B3300SU with FEL, HST, 4-WD and everything else you need in a PACKAGE at an "all-in" price.
Personally, I think you do need additional power of the larger tractor, which is still not very big. Everyone has a budget but it is worth streaching a little more not to be underpowered. When you get out to your food plots you will be very glad to have 14" ground clearance on B3300SU.
Test drive the B3300SU before you order.
LINK KUBOTA B3300SU:
Kubota Tractor Corporation - Tractors | B Series | B3300SU
LINK B3300SU THREADS ON T-B-N:
http://www.tractorbynet.com/forums/search.php?searchid=432780
/ which tractor to buy? #8
Chad, I think either of those would be fine for everything except the 10-15 acres of tillage work you describe. Breaking ground traditionally required something a bit heavier to pull a plow and disc. Substituting a tiller would work, but that is a lot of acreage to till even if you had a bigger tractor with a 6 ft. tiller. If you've never used a 3pt tiller before, it requires you to travel at a slow crawl while it churns the ground. I once did 2 acres of pasture with a 6 ft. tiller and it took me the best part of a day as I recall. Did a great job, but you have to go slow enough for the tiller to do its work.
Grandad4 all the fields have been plowed and disked every year for the last 5 years, so I would not be break new ground. I was thinking of the L3200 but looking at the specs its shorter wheel base and the gpm for the hydraulics are lower by quite abite.
/ which tractor to buy? #10
/ which tractor to buy? #11
That does make a difference, but you still need to travel very slowly. There are many threads here discussing why HST is better than gear drive for a rotary tiller simply because the lowest, slowest gear on most tractors is simply too fast for the tiller to work effectively. We've been using a 6 ft tiller for the last 7 or 8 years and that would be our experience also. Here's a little table that shows the time in hours it takes to make one pass over various acres at different speeds with a 5 ft implement (not counting additional time for turns, and no overlap):
Speed (mph)
0.50 0.75 1.00 1.25 1.50
Acres
1 3.0 2.0 1.5 1.2 1.0
2 6.1 4.0 3.0 2.4 2.0
3 9.1 6.1 4.5 3.6 3.0
4 12.1 8.1 6.1 4.8 4.0
5 15.2 10.1 7.6 6.1 5.1
6 18.2 12.1 9.1 7.3 6.1
7 21.2 14.1 10.6 8.5 7.1
8 24.2 16.2 12.1 9.7 8.1
9 27.3 18.2 13.6 10.9 9.1
10 30.3 20.2 15.2 12.1 10.1
(Well, sorry, the spacing looks fine in the editing box but gets all messed up when it's posted)
I typically make 2 passes, and figure I'm only going .5 or .75 mph... way less than "walking speed" at least. Don't know about you, but running a tiller for 20 or 30 hours isn't my idea of fun, so I just wanted to pass along a friendly "heads up" for you to do your own figuring for this.
/ which tractor to buy? #12
chad26,
I tend to agree with some of the others here. Unless you have lots of time, I think you will be underpowered during tillage with the tractors you are looking at(B2920 and B3200). I do not know your soil, but here you need to moldboard plow, then disk harrow twice for corn and beans. So you are looking at at least 4 trips over that 12 acres when you include planting. A tiller might only be 3 passes total, but I do not think it would be really much quicker in total hours.
You would probably be ok horsepower wise with the other tasks of lane maintenance. Myself, I would look at least at a Kubota L3800 for the tillage. I would look for a 2X14" moldboard plow and 5'-6' disk harrow.
/ which tractor to buy? #13
Chad, the usual response here is to go 'Bigger'. I tend to go with what I can afford to buy out right, no finance. I also like smaller tractors! I'm using a L3800DT on 400 acres, mowing, logging and taking care of several miles of roads/trails. The larger B will do a good job, but I'd be looking at the smaller L series if I were you.
Well, I drove the B2920, B3200 and the L3200. I ruled out the B3200 just because of the vibration. I really like the B2920 but I think it maybe under powered for what I want use it for. Its the perfect size for the up keep on the trails and fixing the roads with the loader, but the fields are my question. The L3200 is more of a tractor I felt. It maybe a little big for the woods, I can always take the FEL off if I need to. I think this would be a much better choice for my needs, plus the price seems very good. Its coming up cheaper than the B2920 by 150.00 dollars. I was quoted L3200HST 4x4 524loader with quick detach bucket R4 tires for 17800.00. I will add cruise that's about 200.00 I think....so does this sound like a good deal?
/ which tractor to buy? #15
Throttle Control is a dealer installed kit. When I bought my tractor in February 2011 the kit was $35.
/ which tractor to buy? #16
Sounds like a good deal. The L3200 is the same size as my L3800 and I use mine in the woods 50% of the time. It's perfect because of it small size and short wheel base. Also, my loader is off most of the time, I only put it on when I need it. I can get through the woods on it just as easy as a ATV. I would highly recommend R-1 ag tires if you have any wet, slick or muddy ground. R-4 tires would make my tractor useless 60% of the time.
That's my biggest question R1 or R4 tires. My dealer states I will be impressed with the R4's they have a bigger foot print and I can load the tires and I will more than enough traction. I do have some pretty steep up hills and the soil is hard packed dark dirt/clay soil and that's in the woods and the fields are a sloping side hills. He also states the R4's have better puncture resistance in the woods and better resale if needed. I plan on this being the one and only tractor I will buy.
I was using a older Ford 1710 a week ago I had the FEL on it and was pulling a 13 foot trailer with 300 gallons of water up a descent slope and I was spinning the tire a little. Granted the woods was wet and sprinkling and its a 26hp tractor. I want to trust my dealer but everyone of my friends that work on farms says no go with the R1's.
/ which tractor to buy? #18
Does the Ford 1710 with spinning tires have functioning 4-WD?
R4s are wider than R1s by a good margin. You need the extra width in front to support full loads in
the bucket.
Few things are more frustrating than a tractor with a punctured tire.
Go with R4 Industrial Tires.
/ which tractor to buy? #19
Everything you dealer said about R-4 tires it true, except the 'more than enough traction' thing. In my experience R-4 tires suck in mud and are almost useless on wet hills. I've been using R-1 AG's in the woods on 4 tractors for over 30 years with never a puncture and more than enough traction. ;)
/ which tractor to buy? #20
I don't guess the Industrial vs Ag will ever be settled, I have Industrial on our L5740 and like the and we have Ags on the M8540 ad like them also. I spent yesterday mowing pretty steep pond levies and never had any slippage and they also work well pulling my Land Pride HR3584 box scrapper in dry to moist ground. They are not however very good in mud or snow.
We do a lot of loader work with both tractors and have never had an issue with the Ag tires. Last year we had two flats, one on each tractor.
