kubota l3400
/ kubota l3400
can you help me? Any suggestions about why my kubota is not running well. It start but struggles to run. I have changed the fuel lift pump and filter. I have bled the system it only has 580 hours on it. I plan on replacing all the fuel and trying a fuel conditioner
/ kubota l3400 #7
How is the air filter?
/ kubota l3400 #9
How old is the fuel? How do know it's the fuel? Did you run it out of fuel?
Details, man , details!
Btw post on the Kubota forum. You will find lots of help,but you have to give info.
/ kubota l3400 #10
James, is there two fuel filters on those?
No it is just like the Kioti. just one fuel filter. but you can have 2 air filters. an inner and outer. That is an option. It is probably growth in the fuel or something like that, but It would not hurt to check the air filtration too.
/ kubota l3400
hey guys...fuel was put in about 3 weeks ago, air filter is good. it was fine one day. problem mightve started after the last fill but not sure. the fill was from the same location that i was filling from for years. i dont run it out of fuel.
/ kubota l3400 #12
drain and refill see what happens. and look for crud on the bottom of tank.
/ kubota l3400
thanks a bunch I have the tractor working now. I removed the tank and flushed it, and replaced fuel with fresh diesel. seems good now. a mechanic suggested to remove the injection pump next but your idea worked.
/ kubota l3400 #14
Must be some stations are selling some really lousy fuel here lately, There have been several reports of bad fuel.
James K0UA
/ kubota l3400 #15
Good Job!
1995 GMC TOPKICK FUEL INJECTION CHASSIS TRUCK (A62130)
1995 GMC TOPKICK...
Headache Rack (A61166)
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
FRONTIER RC2060-60" ROTARY MOWER (A62130)
FRONTIER...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2006 Sterling L9500 Grapple/Storm Truck, VIN # 2FZHAZCV36AV19376 (A61165)
2006 Sterling...
