Buying Advice Tractor Recommendations for slopes
   / Tractor Recommendations for slopes #11
Any tractor with 4wd will be able to handle what you are asking. Spend a little more money and buy something decent. 5k is gonna buy you someone else's trouble.
   / Tractor Recommendations for slopes #12
20% is not steep.
   / Tractor Recommendations for slopes #13
20% is not steep.
Right, 20% is not steep at all, So now she can be at ease looking for a tractor to ride on, instead of walking behind. And she can mow sideways on that mild of a slope.
I always like to get a good perspective on the ground layout before suggesting equipment.
I delivered some stuff on a flatbed trailer to a place in Indiana once, he said "I need you on the hill". I said "what hill"? he pointed to a spot about a hundred yards away that was 2ft higher than our location. To people in my area, a 'hill' could be a place where you wouldn't want to take a tractor at all:)
   / Tractor Recommendations for slopes #14
I concur that 20% is safe. The expression "steep incline" as used by the OP had me worried about her safety.
   / Tractor Recommendations for slopes #15
Me too. But now we know with that type of slope, she can use any type of riding mower for it. It doesn't have to be 4wd. Although 4wd would help greatly if the grass is damp and slippery.
   / Tractor Recommendations for slopes #16
When I mowed for my Mom-in-law there was a hill that I really shouldn't have mowed across. As long as the grass was dry it was possible in 4WD. I usually used the old Ford on the hill because I could keep one cheek on the uphill fender and the other on the seat. The RFM doesn't allow any twisting between it and the tractor, so it was pretty stable so far as rollover from the slope itself. Even in good conditions the tractor tended to "crab" along the hill. My one fear was that I'd slide sideways. There was a concrete retaining wall atthe base of the hill that was flush with the ground I was mowing. The ground on the lower side of the wall was about 18" lower and the rusty pipe fence at the bottom would have served no purpose other than to be something to hurt on the way through it. A few times when the grass was damp it did start to slide. I steered sharply uphill and floored it and the tractor got itself pointed uphill.
Here's a pic and it doesn't look as bad as it really felt. That may be partly due to the utility pole behind me being out of plumb.
   / Tractor Recommendations for slopes #17
So what is the max angle, specifically, what is the tipping point of an average tractor with say loaded R1 tires?
   / Tractor Recommendations for slopes #18
That is going to depend on the tractor itself.
If you look at the typical SUBCUT lineup, the typical Kubota has a width of 44 inches, my Massey is listed as 47 inches, and the Mahindra, is 50 inches. Then you have to look at how high that weight is above the ground(center of gravity). All tractors differ, there really isn't a 'set rule'.
   / Tractor Recommendations for slopes #19
Judging by the tractor itself(if the camera is level) it appears to be approaching 40% slope on yours.
But judging by the roofline of the house, the camera isn't level. So maybe 35% slope?
   / Tractor Recommendations for slopes #20
I have a program called Screen Protractor.
Barn:
Tractor:
2007 FORD F-550 XL SUPER DUTY CHASSIS TRUCK (A58375)
2007 FORD F-550 XL...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
13046TX (A55973)
13046TX (A55973)
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
