Eatin' belts
/ Eatin' belts #21
Look and see if the bottoms of the belt pulleys (belt groove) could have rust that could wear the belt. Check to see if the tensioner is worn causing the belt to run crooked in the pulleys. The only other thing is belt alignment.
/ Eatin' belts #22
One remote possibility if you are mowing tall heavy wet grass and the belt is slipping and burning as you mow and develops weak or stretched areas which causes the flopping in time. If this is true then mowing slower in those conditions would save the belt. Just a thought as you seem to have covered everything else.
/ Eatin' belts #23
Do you have a picture of the broken belt? Might help point in the right direction.
/ Eatin' belts #24
3" of heavy wet mulch 48" wide plus the uncut grass underneath? Not talking about dry fluff
So he was blowing the clippings into the uncut grass, not just "re-mowing/re-mulching the clippings from the precious passes"
I have mowed lawns commercially and we would frequently "re-mow/re-mulch the clippings from the precious passes" when there were a lot of clippings as our contract stipulated that there were not to be any visible clippings left when we were done and double cutting or triple cutting (the industry term for that) would get them small enough that they would mulch down quickly and not be left in visible clumps.
Aaron Z
/ Eatin' belts #25
"After a few weeks mowing belt slaps' around and under the covers and all over top of deck is all black rubber."
Sounds like to me your describing a bearing that is not spinning freely. I just have a problem taking someone elses word that somethings ok when its apparent that its not , i would pull all the bearings and check them. If they feel the least bit rough when you turn them by hand think how that multiplys at 1000+ rpm
/ Eatin' belts #26
If you take the time and trouble to pull the bearings there is no way I would put the old ones back in no matter how good they look. Not that costly to replace and be sure you didn't miss anything. Like has been said, they may feel okay without tension and pressure on them but not in actual use. Always hate getting in a "replace parts til you find it situation.
/ Eatin' belts #28
Sounds like someone needs to buy a mower that discharges on the left??:laughing:
/ Eatin' belts
Ok . After further investigation I believe this was caused by owner error,me. I changed the first two belts. I read manual removed deck and the drive gearbox, installed new belt slapped her back together. Both times same way. After posting and checking for pulley alignment I think I found the problem. The complete unit gearbox drive pulley assembly bracket can be slightly adjusted at the rear mounting bolts, I just tossed in it and tightened it up. Today with just a visual check I can clearly see drive pulley at least 1/4" lower then the blade pulleys. And that pulley is very close to the center blade pulley ( 1/2" can't even squeeze belt throught it) I loosened the rear bolts and can pry it up to level.Is this my problem ? However still need a new belt.
Next issue. I noticed one of the pulleys has rust in the groove area not shinny from belt wear. It's rusty enough feels like very course emery cloth /sand paper. My thoughts now install new bearings, idler arm bearing/bushing, and new pulleys if needed. I don't want to mess with this for awhile. I'd post some photos but don't understand new photobucket. I can up load photos just can't find em
Thanks for the help more advice on this issue
cheerz
gregz
/ Eatin' belts #30
Polish the rust with some sandpaper. Once running, the belt will keep it polished for you.
As to the pulley mis-alignment, you bet. 1/4" off will definataly eat belts.
/ Eatin' belts #33
You can go to jdparts.deere.com and view a parts catalog for your deck. If you register you can even get your local deere dealers pricing and check inventory of parts.
/ Eatin' belts #34
cheerz
gregz
That much rust indicates the belt has been installed incorrectly or its a pulley that is not used. Are you sure the belt is being installed right or are you just copying what the previous owner did? By the way, a belt should not sit so deep into a groove that it touches the bottom. It should 'wedge' against the sides, so the sides will get shiny but not the bottom of the groove. Belts come in different widths so make sure its the correct width as well as the correct length.
/ Eatin' belts #35
While not much of a rider mower guy, I do know that rusted pulley will sure chew up a belt real fast.
You want those pulleys to be like a mirror, and free from any nicks as well.
Being real careful and using emery paper run the mower at low RPM with paper wrapped on a stick and polish the pulleys to a mirror finish.
I cured a pals belt chewing mower this way.
BUT careful is the word.
/ Eatin' belts
well I was trying to add a photo but new photobucket is way to advanced for me. why they change that chit I don't know
Anyhow the rust on the pulleys if from non use. Deck has been unused in storage for 10-15 years . aside faded paint looks new condition I believe my main problem is pulley alignment. I clean up the grooves, or might have to pick up one or two new pulleys
http://s136.photobucket.com/user/gr...aaaaaaaaaaaa_zps231f3819.jpeg.html?sort=4&o=1
/ Eatin' belts
There's not a chance in **** I'll try that. Just fork out the cash buy new pulleys save me a trip to the emergency room
/ Eatin' belts #38
Aa Photo by gregjanko | Photobucket
here is the picture
You just need to copy and paste the IMG code.
/ Eatin' belts #39
To add the photo directly to your post just click on "Go Advanced" at the bottom of the reply box. Then click "Manage Attachements". Then "Add Files" and browse to choose your pic file to "Upload". Then "Done" and post it.
/ Eatin' belts
Spindle bearings.
I have them off the deck. They do not wiggle, seem tight. Should they make any noise when spin. Each one has a low metal on metal sound not grinding. Spin by hand they will only spin a complete turn or two. Diffinently not quiet or smooth like a motorcycle wheel bearing?
Two belts ruined now I have to buy a third. Deck is off for the third time. Should I just go ahead bring em in and have the dealer install all new bearings.
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
Cub cadet LTX1045 Lawn Mower (A63116)
Cub cadet LTX1045...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63118)
Timpte 720 All...
New/Unused Wolverine 72in Quick Attach Tiller (A61166)
New/Unused...
