Turbocharging new L3940 Gutless Pig Tractor
Status
Not open for further replies.
   / Turbocharging new L3940 Gutless Pig Tractor #51
Since H is for hill is M for Mud and L for level?
   / Turbocharging new L3940 Gutless Pig Tractor #52
The Fred
Just a thought.....I have hilly land also and when working ground engaging implements I always try to work down hill and let gravity be my Polish Turbo.:laughing: It works try it.
   / Turbocharging new L3940 Gutless Pig Tractor #53
Fred, I'm sorry to tell you this but that land plane is too big for your tractor. Even the 4740 would struggle at times pulling it up steep hills pulling your grader. I use a 6' plane simply because bigger isn't faster. 5' would work fine as well. A 5' grader will cover 9' plus with one pass up and then down the hill. Once you get more HP you are now going to wonder if the HST transmission is designed to handle the extra power. You'll also need to add weight as your tractor now has more power to break the tires loose. On top of that when using a grader on hills traction becomes an issue. Your first pass will be driving on packed gravel but after that you'll be driving on gravel that you just loosened the pass before. If given the choice I would size the attachment to the tractor and not try to beef up the HP.
If you do try and add a turbo please document it and keeps us informed. I would like to see it done.
   / Turbocharging new L3940 Gutless Pig Tractor #54
The Fred
I try to do the same but often find that the bottom of the hill is where all the gravel ends up and needs to be pulled back up. But for me traction is a much bigger problem than HP.
   / Turbocharging new L3940 Gutless Pig Tractor #55
The Fred,
In reading your earlier posts you joined in June of this year and must have bought your Kubota in June or July (this month). One post says you are an automotive technician which doesn't compute if "H is for hill". With all due respect, I suggest that anyone use a new tractor within its capabilities and with reason and give it lots of hours (hundreds) before coming to hard conclusions. Your L3940 is a credible machine.
   / Turbocharging new L3940 Gutless Pig Tractor #56
The Fred,
Yep! 8' land leveler with all those tines is asking a little much, especially on steep terrain.
That's kinda like buying a 1/2 ton truck and complaining when it won't pull your gooseneck trailer up the mountain in the fast lane.
   / Turbocharging new L3940 Gutless Pig Tractor #57
Trade the dang thing in for a MX5100 gear drive and be done with. You just got the wrong tractor! HST is part of the problem.
Maybe I should post this in the Deere forum.
Status
TMA (A49461)
TMA (A49461)
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
1997 HUBBLER BROS. LOGGING TRAILER (A50854)
1997 HUBBLER BROS...
