Rope for pulling trees over
/ Rope for pulling trees over #21
I use the winch on my ATV to raise and lower a snow blade. The original steel aircraft cable that came with my Warn winch self destructed in the spool. It frayed and broke after one year of use. I replaced it with Amsteel Blue winch rope. I have been using this Amsteel Blue for 6 years in my winch now with no noticeable signs of wear. Not so expensive now compared to replacing the steel aircraft cable every year for the past six years.
What cable are you replacing every year?
Nevermind... I'm dumb.. :)
/ Rope for pulling trees over #22
Hmmm... yes expensive, but looks very interesting! Thanks for sharing. The material is UHMWPE (ultra high molecular weight polyethylene). This plastic is very tough and strong and used by the Navy for well decks and ballistic armor to name a few applications. I might have to invest in some of this rope. But it is not cheap! What also is exciting is the light weight aspect. No more having to lug heavy chains and trying to throw them around things.
Another major aspect is safety - if this pops free, there is a lot less kinetic energy released to bystanders. The same cannot be said when a chain or wire rope lets go.
David
/ Rope for pulling trees over #23
My sons and I have cut down a lot of trees over the years. I used to sell firewood and then for a long time we heated our house with a fireplace and my wife loves a big fire, so she burned a lot of wood.
I tie a piece of 1/4" nylon rope to a 2lb hammer and throw it over a limb high in the tree. I then use it to pull a 3/4" rope up and over the limb and tie an eye in it to pull a loop tight to the tree.
I then tie the end of the rope to the front of my truck or my favorite tree puller, my wife's Honda Pilot.
I have the wife or son or me, depending on who is helping take the slack out of the rope by backing up.
I cut the notch in the tree in the direction I want it to fall.
I start making my cut from the other side as as soon as the tree starts to move I nod my head up and down, my driver knows this means to back up a little more keeping slack out of the rope and does so, pulling the tree exactly in the direction we want as I finish the cut.
I have also used the tractor, but since it has a clutch, it is not as easy to keep steady tension on the rope.
I have also used left over 5/16" cable I got free from work, but I would rather work with rope.
As someone said above, if I were closer to the beginning of my tree cutting I would look at the blue rope. The problems I have had with rope is keeping them long and not having to tie several together. With three sons growing up with four wheelers and 4wd vehicles my ropes sometimes got shorter, or drug in two or ugly hatchet knots in the middle of them. Now that they are grown I think my ropes will last a long time.
/ Rope for pulling trees over #25
I think that the operative difference is the obviously significant weight of the : "very heavy braided military rope...~1" thick", which per foot had to vastly outweigh a similar diameter of a newer rope like the Amsteel Blue (or of the several knockoffs/wannabes I have seen) which per diameter is also massively stronger.
I have broken wire rope/cable, tow chains and straps (despite slow non-kinetic pulling), and the straps behaved very differently from the chains and cable, which which whiplashed dangerously. The strap was limp spaghetti immediately without any spring back, despite the amount of stretch/elasticity it displayed.
I just ordered the Amsteel Blue that has been sitting on my EBay watchlist and Amazon wishlist for over a year because the 20' double-eye ended rope they had in their "garage sale" was half the price of a 25' piece at the regular price, and for my plow winch (a HF 3k-rated cheapie) the 4900# working limit of their 3/16" rope is plenty, and rope that thin will also take up less space on my drum.
For comparison, 3/16" galvanized is typically rated at 3700#, and is stiffer and heavier, though much less expensive at approx $15/1000'.
For me it's,more about the failure rate of the metal cable and having to repair or replace it in 3' of snow while trying to clear the driveway- and of course it always breaks at 0200 (AM) at the far end of the 1000' driveway.
Thomas
/ Rope for pulling trees over #27
I bought a new nylon 3/4 inch rope reel (150 feet) at Lowes. Using different methods I fish a 1/4" nylon rope as I high as necessary to pull the 3/4 " up into the tree. Most of these are 40-50 ft dead pine trees. Working by myself usually, I tie the main rope to the front hooks of my Super Duty and put some tension in the direction of the fall. Then I do the cut accordingly until it looks like enough. Then I do the rest with the truck. If it is a critical fall, I get my neighbor buddy to do the cutting after I've prepared everything. Don't use questionable rope that is old, rotten or damaged. This has worked for me in about 20 falls, even around power lines and the house.
/ Rope for pulling trees over #28
I had a 70' 12" dia. fairly straight tree about 10' next to my new pole building. The fall should have been easy because the long driveway was right parallel with the building. I tied a 100' cable about 15' up the tree and the other end to the hooks on my dually with tension on the cable. My wife was in the truck, and I told her that when I cut the tree and it starts to tip a little, start pulling down the driveway. Simple enough. The tree would fall parallel with the garage on the driveway. I put a little notch in the front, then I started cutting the rear. As soon as I saw the tree was going to fall, or close to it, I backed up and waved my arms to go. She got confused by that and stayed put. After the tension left the cable the tree fell where it wanted to and barely missed the corner of the shed. I fired her.:D
/ Rope for pulling trees over #29
I pound a large spike [ painted orange or with orange marking tape on it ] up above where my ladder reaches to, and use this to help put the chain around the trunk. Then hook a 1/2" steel cable to the chain. I put a big wide nylon strap around the tree base I am falling towards. Then hook the tree strap to the steel cable with two come-alongs and fill the rest with chain. I use the first come along to take up the slack in the setup and get the cable fairly taught. Then walk the setup and make sure everything is still hooked up right along the pull line. Notch the tree in that direction..then put lots more tension on the cable. I make a partial cut thru the trunk, then readd tension to the cable. Wait a few minutes... cut... tension... wait a few... repeat. In the 'wait' periods you will start to hear the trunk as it breaks at the cut point. You can actually stop cutting, and just slowly pull the tree over. As with all things, make a wide path between the trunk and the come alongs, and watch your arse.....
/ Rope for pulling trees over #30
Thats a good point, probably good idea to go over your plan and hand signals with your helper.
/ Rope for pulling trees over #31
In all respect to wives, mine helped stretch some fence with the truck. I signaled for her to give it a little pull. Nothing happened??? So I went up to the window and found that the brake was on. So we started all over. This time when I signaled to pull a little, she gassed it and pulled all the post out of the ground.:confused3:
/ Rope for pulling trees over #32
Okay, that's funny :laughing::laughing::laughing:
/ Rope for pulling trees over #33
That needs to go into a movie somewhere... :drink:
/ Rope for pulling trees over #34
I can definitely recommend getting the 'right' rope. I tried to fell a tree near a garage, it had too much weigh ton one side (unkown to me part of it was hollow making it VERY unbalanced though it was only leaning a little). I used a ladder, put a rope pretty high up, got it all rigged up to pull with a vehicle and made the cuts. I got it so there was maybe an inch left and it was barely there and my saw got stuck. I figured I'll just pull with the truck to get it to go. Well when I pulled the rope broke, the tree swayed, but did not fall - but was clearly going for the garage. It wasn't safe to use a ladder again to try and get a high rope on it and I did not have any rope strong enough for the job. It ultimately ended up falling directly on the garage. I spent the rest of the day on the garage cutting the tree off and then patching the holes in the roof and fixing the siding... lesson learned, now I only use very heavy duty chain.
I never found a 30' strap exactly like i want. I am still going to get one.
I am revisiting the rope idea too.
I was going to order this one but it is out of stock. 11,800 break strength
Bailey's - 9/16" BlackMAX DB Yellow Bull Rope
My second choice was this one. 10,400 break strength
Bailey's - 1/2" Samson Stable Braid Blue Bull Rope
Then I got to thinking about amsteel blue again:confused2: I know with a rope if you tie a know it can reduce its strength between 20 and 40 percent. Splicing it doesn't hurt it in most cases. The amsteel blue has a thimble on it or one on each end. So if I went with the 3/16 amsteel to stay on my budget:eek: How could I attach it to the tree with out reducing its strength? Then it would be about as strong as the other ropes I mentioned with a knot in them. If I got one with a hook and pulled the rope through the hook would it greatly reduce the strength? My other idea is a short tow strap and hook the amsteel to that. Any other ideas?
/ Rope for pulling trees over #37
In addition to the Amsteel Blue winch rope that I bought for my ATV I bought an Amsteel Blue 100' 5/16" winch extension. This winch extension rope does have permanent thimbles woven into each end. It also has nylon protective sleeves on each end that can be slid to protect this rope. This rope is very tough. Although I do slide the line protectors down when cinching a log I think this rope is tough enough to go without the nylon protector. It is called a rope but it really isn't a rope. It's much stronger than steel, has less stretch than steel, and lasts longer than steel. It is a bit pricey. But I've been using mine for a few years now with no noticeable sign of wear. It's much easier to work with than steel cable. It was a good investment for me.
/ Rope for pulling trees over #38
Amsteel blue is great stuff, but you can get by with standard logging rope in 5/8" or 3/4" and it will still last a lifetime for most of us. Sampson makes good logging rope, but expect to spend about $1.20-2.00 per foot. Also get a pulley block so that you can pull in a direction away from the fall or use it to increase mechanical advantage (or get two pulleys if you want to do both). And then some shackles, and a tree strap or towing strap for anchoring. I spent about $300 on all this stuff a few years ago, and it was money well spent. I use an old duffel bag to stuff my rope into to keep it clean and tangle free.
Putting long rope in a bucket is a secret tip! Do this all the time with long rope (300ft+) for shrimping, etc. amazingly stuffing the rope in a bucket when hauling it in and it never tangles!
/ Rope for pulling trees over #39
Have you ever used a wedge? Takes the place of a rope any day. When was the last time you saw a faller use a rope? Wedges can make a tree leaning the wrong way fall where you want it to fall. Look on utube. Good stuff amigos!!
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
1994 Hyster H80XL 8,800lb Straight Mast Diesel Forklift (A66734)
1994 Hyster H80XL...
2017 PETERBILT 579 (A67714)
2017 PETERBILT 579...
