Captain Ledd
Most of my resources for rebuilding this thing have come from this website. I'm really hoping someone can help me out.
2nd post here, and I've run into a bit of a head scratcher.
I have an old Mott Flail mower (60's?) that I'm rebuilding/restoring for me and my neighbor to use. Mostly it's just required bearings and a bit (a LOT) of welding back together. But while painting the gearbox and sitting it on it's side it became MOST apparent that the seals were no good... Measured shafts and openings, ordered nice double lip neoprene seals, went to pry the old seals out and I swear the front (input) seal case was made out of spring steel or something (turned out it was just a FELT seal too!), the side seal (output) was a normal seal, and wasn't an issue.
But this front seal I just could not remove, the only direction it went was farther into the gearbox. So I figured I'd just pop the front cover off (which I was kinda trying to avoid seeing as it was already painted) and replace the seal that way.
Well, there's my problem, the cover is STUCK about 1/8" up from the face of the housing, I'm bending screwdrivers prying on it and I don't want to break or bend anything, especially the cover. But I can't even get a good look in there to see what it's caught on. Any help or diagrams on how this thing comes apart would be great. It's got a different style housing than basically every other Mott I've seen, I have searched.
(hopefully my attachment works)
