HVAC question
/ HVAC question #1
Pixguy
Super Star Member
By the lake in NH & FL
2011 MF 2410 TLB
First, i am a fairly handy homeowner i had to be as im no Brad Pitt. ;)I roughed the new home and my brother, a licensed elec tied in the panel. Bear with my explanation.
We have a home with 2 split systems, 1 is 3 ton EMI I believe and the MB is 1.5 Bryant due to it being upstairs.
The two vertical standing condensers are next to each other outside of course and I always made sure that the leaves are cleared from behind so that it would breath properly and covered for the off season. 3 weeks ago the small unit stopped working during the night. Blowing indoors but nothing out except for an occasional buzzing. I pulled the cover off (while shutoff was pulled) and noticed that the inside of the coils were a good 1/8 thick of dust. Hmmm, why inside and not out?
While plugging in breaker bar(?) it starting to hum and the fan did not blow so I gave it a light push CCW and it started working but I could tell the condenser was not kicking on. But the fan was blowing towards the house instead of the obvious direction(to a novice). I stopped it, pushed the fan the other direction (CW) and it worked that way too.
Finally the plumber who installed it came, I told him the issues including my fan test and he came back a few days later with a new capacitor. All seems fine but I noticed today that the fan is still running CW and it is sucking air in towards the house. Is that correct? shouldn't the fan be pulling the air from the rear through the coils and away from the house, like the other unit does? Thanks for your time.
/ HVAC question #2
In my experience, the fan on the condenser unit should blow out. In other words, it should blow your hair back when you put your face over it. Some are multi directional and can be switched at the fan plug.
/ HVAC question #3
I tend to believe it should force the air in thru the coils, but can you post a picture of this unit?
/ HVAC question #4
Most condensing units pull air thru coils, doing in essence 2 jobs in 1. Cools coils and compressor, removing the heat caused by the compressor in operation.
/ HVAC question #5
Thank you for your vote of confidence.
/ HVAC question #6
I would say the condenser fan pulls air through /across the coils, and cools the refrigerant that is circulated through the coils
To the op. It's hard to say (without pics) which way the fan should turn on your A/C unit. some fans turn cc and some turn ccw
/ HVAC question #7
I worked on residential hvac units for about 10 years until switching careers. It has been 5 years or so. Units have changed tremendously since. I left just as R410 freon came about.
/ HVAC question #8
I have been a licensed HVAC tech for 28 years and owned my own business. We need pics to be sure of what the op is talking about.
/ HVAC question #9
Agreed. Just sharing my experiences.
/ HVAC question #10
Deerfan is correct to say most (if not all) residential condensing units blow out. It is probably more correct to say they are set up to draw though the coils, where the coils are upstream and the prop is downstream, in direction of airflow. It is possible to do this in a blow through arrangement where the coils are downstream (prop blows through coils), but I have never seen it in residential units. Not saying it doesn't exist, just haven't seen it - for sure it's not too common. If the prop is turning in reverse rotation there would be heat rejection, but not to full capacity. If the unit is fairly new there should be a rotation decal on the unit casing, the prop itself, or both. If not, a call to the unit manufacturer would clear things up.
There is also a newer prop type referred to as swept blade or swept wing, and it's not as easy to identify proper rotation at a glance. However they are usually installed in the same draw through configuration.
Any chance you could post a photo or two?
/ HVAC question #11
Most fan blades are curved. If you look at them, you can see they they would be very ineffective in the wrong rotation.
That should give you a good indication which direction the air is supposed to move.
/ HVAC question
Thanks for all the input. Yea too dark last night to take pix but here they are.
Units are 10 years old, vacation home til last year, so not used like a full time home til now.
Unit on right in question.
The units were installed by plumber who's a great guy but limited knowledge in HVAC. I thought it was possible that the fan has been turning the wrong way the entire time, no? Blowing towards house?
/ HVAC question #13
Blow towards the house I think
/ HVAC question #14
That fan is designed to pull air into the box from the front side. It would exhaust out through the coil as you describe. If you look at the other fan that blows out away from the house you should see the trailing edge of the fan blade is curved toward you. The other indicator of airflow direction is the curved throat around the fan. The fan should turn clockwise when looking from the front.
/ HVAC question #15
It is definitely blow through, as others mentioned. Rotation of the prop should be clockwise, viewed facing the prop hub. Another way to tell in this unit is by looking at the fan mounting panel. The smooth radius edge is the inlet and the fluted or sharp edge is the discharge. I am guessing the horizontal airflow type condensers probably use this more often. Not the most efficient design, but gets the job done and makes the unit a lot more compact. Also explains why inside coil rows get dirty first.
/ HVAC question
OK, I agree and appreciate all comments. I will just be more diligent by cleaning the inside more often. It doesn't seem as efficient as some say to push towards the house, which is 16"(?) away.
We will be looking to replace these in the coming years and add another(vaulted ceilings, no room for ducts) which units are the best? Fujitsu, Mitsubishi are the ones I see.
Yes, we get both extreme cold and hot, reached 102 in sun last week.
/ HVAC question #17
Thanks for the pics. I have not worked on these type units before, not very familiar with them. My input was geared toward the more upright units where the fan pulls air across the coils and out. Sorry for any confusion.
/ HVAC question #18
I see these used for industry users, not used in residential around here.
/ HVAC question #19
This type of unit is being used more in the US for residential, especially in areas where ductwork isn't possible or desirable. Another plus is turndown capability, as you can turn off AC in vacant rooms more efficiently, and at a lower cost than having a multi-zone ducted system. Only downside to me is what to do with small rooms like bath, etc, and having to look at the units on the wall. In an area with vaulted ceilings where there's a lot of open space they are probably a good option, especially if you don't want to mess with ductwork.
Don't have a lot of direct experience with these, but suggest adding Daikin to the list of mfrs to check out. They have pioneered a lot of the newer, more efficient units, and definitely worth a look.
Residential | Product | Daikin Industries, Ltd.
/ HVAC question #20
If your not running duct work your running a line set to each room. plus power to a fan.
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2024 JCB 3TS8T Teleskid High Flow Compact Tracker Loader Skid Steer (A66734)
2024 JCB 3TS8T...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
2012 CHEVROLET CRUZE CAR (A66091)
2012 CHEVROLET...
PALLET OF HEAVYEQUIPMENT PRESSURE WASHER PARTS (A68842)
PALLET OF...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
