Pat's Easy Change Hydraulic Fitting Question
/ Hydraulic Fitting Question #1
deere5105
South Mississippi
2008 John Deere 5303 MFWD, 2004 John Deere 5205
I need to swap the hose locations on the two shown in the picture. It doesn't seem there is a release for the fitting to pull loose. Have swapped before on my tractor, but this is someone else's. Seems I am missing something likely very simple...
Not sure how post got where it did. Here is pic.
/ Hydraulic Fitting Question #3
And what does this have to do with Pat's easy change???
Absolutely nothing. Not sure how to correct from mobile device where it originated and got too much mowing to do to stop and research.
/ Hydraulic Fitting Question #7
Just go to edit post and delete.
/ Hydraulic Fitting Question #8
Push in, then pull out, all in one quick motion. That should get them disconnected.
/ Hydraulic Fitting Question #10
They appear to be like the Kubota-style quick disconnects. Make sure all of the pressure is off of the fittings and then give them a yank. If they have even a little bit of pressure they aren't coming apart.
Sounds counter-intuitive but that is the way mine work.
/ Hydraulic Fitting Question #11
With a green step looks like a John Deere mid mount loader quick couplers.
Make sure the loader is down, so it will not have pressure in the lines. Machine not running relieve pressure in lines.
Push outer ring towards tractor pull out hose end.
/ Hydraulic Fitting Question #12
With a green step looks like a John Deere mid mount loader quick couplers.....
......Push outer ring towards tractor pull out hose end.
No outer ring on those and the are the same ones Kubota uses. They are made by a company called Faster.
As already stated, grab hose and in one quick motion push in then pull back.
These are the mid mount on a John Deere 5205. This is a neighbors tractor and they have been that way for as long as I can remember. On my JD 5303 my mid mount have a sleeve you push back and pull fitting off. This one does not. I do some mowing for her a few times a year. Was able to put in around nine hours today and got finished. Next time down will try the methods described. I have seen people push and pull quickly to remove, but was concerned I would damage something. Sounds like that is the consensus though on how to remove them.
Now if I can only figure out how I got Pat's Easy Change in with the subject line!!
/ Hydraulic Fitting Question #14
One of the keys to hydraulic line removal seems to be to make sure that the pressure if totally off the line. After turning off the tractor, move the controls through all positions to remove pressure. Might help to repeat going through all positions. Then try the removal.
/ Hydraulic Fitting Question #15
Could be one of these.
Faster Quick Disconnects
CPV-CNV Series
Quick-release couplings mainly
used in agriculture.
Push-Pull system makes
connection and disconnection
very easy.
Conformity to ISO 7241-1 part A
standards ensures worldwide
interchangeabilit
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
213130 (A64276)
213130 (A64276)
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2015 Ford F-550 4x4 Mason Dump Truck (A66736)
2015 Ford F-550...
BOBCAT 435AG (A68134)
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A66734)
2019 Cub Cadet...
