correct wrench
  • Thread starter washita
  • Start date
/ correct wrench #1
W
washita
Guest
what is the correct wrench size for the pivot point nut (jesus nut) on the 425 series pt? normally I use a large crescent wrench for this nut , but after adding a couple of divots to my hand this past weekend it is time to invest in the proper/correct wrench
/ correct wrench #4
Page 18 of my 2010 PT425 parts manual is attached below. The nut may be item 7: 1 1/4-12 half locknut. Hope this helps.
/ correct wrench #5
1 and 13/16 maybe?
++1 for a 2005 PT-422. Just went outside and checked the wrench and the nut,.
Still tight. :)
Remember, wrench size and bolt sizes are different. Quick google shows that the standard wrench size for a 1-1/4" bolt is 1-7/8". But 1-13/16" fits mine quite well.
US Bolts - Head and Wrench Sizes
/ correct wrench #6
If you don't have one of these vernier1.gif, you can use the crescent wrench to find the size. Put it tightly on the nut, then measure the opening with a ruler..
/ correct wrench #7
Still tight. :)
That link has the answer to every question if you can uderstand it. I played with it a few minutes and found answers to questions that shouldn't be ask by responsible(?) TBN members :D
Smilinjak
/ correct wrench #9
I seem to recall the formula for wrench size is to take the bolt diameter + add half the diameter to it to get the wrench size. Add an additional 1/8" for heavy hex nuts. So a 1" bolt would be 1" +1/2"=1 1/2" for wrench size on a standard nut or 1 5/8" if it is a heavy hex nut.
/ correct wrench #13
So what is the torque we are supposed to tighten it to? Or is it just tighten it to just plain tight :D
/ correct wrench #15
On a bolt that size you aren't likely to over tighten it unless you you are so strong that "finger tight" twists off a 3/8 grade 8 bolt.:D:D
Smilinjak
2011 WESTERN STAR  4900 SB (A63569)
2011 WESTERN STAR...
2005 FRAC TANK 500BBL WHEELED (A63569)
2005 FRAC TANK...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
4R CHISEL RIPPER BEDDER (A63291)
4R CHISEL RIPPER...
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
ATLAS DRILL PRESS (A63569)
ATLAS DRILL PRESS...
