correct wrench
  • Thread starter washita
  • Start date
/ correct wrench #1
W
washita
Guest
what is the correct wrench size for the pivot point nut (jesus nut) on the 425 series pt? normally I use a large crescent wrench for this nut , but after adding a couple of divots to my hand this past weekend it is time to invest in the proper/correct wrench
/ correct wrench #4
Page 18 of my 2010 PT425 parts manual is attached below. The nut may be item 7: 1 1/4-12 half locknut. Hope this helps.
/ correct wrench #5
1 and 13/16 maybe?
++1 for a 2005 PT-422. Just went outside and checked the wrench and the nut,.
Still tight. :)
Remember, wrench size and bolt sizes are different. Quick google shows that the standard wrench size for a 1-1/4" bolt is 1-7/8". But 1-13/16" fits mine quite well.
US Bolts - Head and Wrench Sizes
/ correct wrench #6
If you don't have one of these vernier1.gif, you can use the crescent wrench to find the size. Put it tightly on the nut, then measure the opening with a ruler..
/ correct wrench #7
Still tight. :)
That link has the answer to every question if you can uderstand it. I played with it a few minutes and found answers to questions that shouldn't be ask by responsible(?) TBN members :D
Smilinjak
/ correct wrench #9
I seem to recall the formula for wrench size is to take the bolt diameter + add half the diameter to it to get the wrench size. Add an additional 1/8" for heavy hex nuts. So a 1" bolt would be 1" +1/2"=1 1/2" for wrench size on a standard nut or 1 5/8" if it is a heavy hex nut.
/ correct wrench #13
So what is the torque we are supposed to tighten it to? Or is it just tighten it to just plain tight :D
/ correct wrench #15
On a bolt that size you aren't likely to over tighten it unless you you are so strong that "finger tight" twists off a 3/8 grade 8 bolt.:D:D
Smilinjak
2022 EZ-GO ELITE...
2021 BOBCAT E50 R2 SERIES EXCAVATOR (A63276)
2021 BOBCAT E50 R2...
2013 29ft. Larson LXI292 Boat with 2007 30ft Loadmaster T/A Boat Trailer (A64557)
2013 29ft. Larson...
2002 FORD UTILIMASTER 4X2 S/A STEP VAN (A67148)
2002 FORD...
2006 INTERNATIONAL 7400 4X2 VACUUM EXCAVATION TRK (A63276)
2006 INTERNATIONAL...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
