sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,838
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Quick farm wagon build---with photos
For a while I've needed a smaller type "hay wagon" around here but didn't really want the size of an 8' x 16' wagon. Opportunity found me when I found an old wagon frame with four nearly new rib implement tires on it that I needed elsewhere. The wagon paid me to buy it.
So I stripped it down, scraped the loose paint and pressure washed it. Then primed and painted it the original red color.
The rails are PT 2" x 8" x 12' and I had some old 4" x 4" PT posts I cut to 7' long and bolted down.
The floor is 3/4" PT plywood that got ring-shank nailed down as did the trim boards. Packed the wheel bearings and new grease seals and will add tail lights and an SMV sign later.
Was an easy build and is perfect for my intended use and who knows, I might use as a parade wagon. You can build this in a long afternoon.
