SCV question???
/ SCV question??? #1
GYPSY
^ Mason Dixon
JOHN DEERE
hi y'all..a quick question??? i have 2 remotes on the back of my 5420 that have the control levers on the right side console. lever 1 i have in float(all the way forward), full detent and lever 2 will go full forward but not into detent??? in float the hydraulics needs no engine power and yet in neutral, on lever 2, there is no engine piwer used, like its in float. should both not be in float if pushed fully forward to not use hydraulic/engine power. #2 has me a bit puzzled. in neutral it seems like its in float..thanks for the help..hope i described this well.
gypsy
/ SCV question??? #2
It's possible the SCV valves are designed for future loader use. One has float for the boom and the other has regenerative for the bucket.
/ SCV question??? #3
I guess he has a loader joystick for his scv's? Mines like that.
/ SCV question???
thanks y'all, i have dedicated midmount for the loader and 2 optional out back, sound like lever 2 or scv 2 is in neutral when in the middle position, as for loader work??? makes sense, so is this correct??? thanks again
/ SCV question??? #5
Yes for the loader control if you push it all the way forward and you hear a click, its in the float position, same as the levers.
/ SCV question??? #6
Hydraulics:
Type: open center
Capacity: 10 gal [37.9 L]
11.5 gal [43.5 L] (PowrReverser)
Pressure: 2800 psi [193.1 bar]
Valves: 2 to 3
Pump flow: 15.9 gpm [60.2 lpm]
Steering flow: 6.6 gpm [25.0 lpm]
Steering press.: 1900 psi [131.0 bar]
In an open center hyd system, there is a continuous flow of fluid through all the valves in series when the levers are in neutral.
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A62129)
CATERPILLAR 631E...
2022 John Deere HPX615E 4x4 Gas Utility Cart (A61567)
2022 John Deere...
New/Unused CFG Industrial QH12R Mini Excavator (A61166)
New/Unused CFG...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2022 BOBCAT E35 R2-SERIES PLATINUM EXCAVATOR (A62129)
2022 BOBCAT E35...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
