Discbine rattles
   / Discbine rattles #11
CV joint is 2 u-joints close together with a ball & socket in between the 2 u-joints. Photo is a cv driveline for a JD rd baler.
   / Discbine rattles
Ah ok, no mine doesn't have one, my inner shaft going to the gearbox used to have one but the previous owner removed it and put a regular u-joint in its place. I was told that cause of that I can't use the Discbine in the retracted position (to steer around corners.)
Is it possible to replace just the end with a cv driveline like it used to be?
But at the moment the shaft going to the tractor is the one vibrating and it's just u-joints not cv.
   / Discbine rattles #13
The reason the PO did away with the CV joint on your Mo-Co is $$$$$$$. They are expensive to repair/replace. It is true that you can no longer operate pto in anything but the field position with CV joint missing.
   / Discbine rattles
Yep I priced one out today and wished I didn't, they sell the shaft each side individually, the front part was $2842.03 and the rear part was $3322.31, that's $6306.44 for the whole shaft (OUCH) I will stick to operating it only in field position, just have to figure out why it's rattling so much on steep turns.
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
New/Unused Electric Golf Cart (A57453)
New/Unused...
John Deere 1025R (A53317)
John Deere 1025R...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2000 FORD F-650 SUPER DUTY (A58214)
2000 FORD F-650...
Hose Reel (A55787)
Hose Reel (A55787)
