Massey power steering hard left
/ Massey power steering hard left #1
jimmasters
dalton ga
ford 5600
Working on steering or non-steering as it may be, I put fluid in reservoir , started eng. & it immediately turned hard left & wouldn't, couldn't steer until I took line loose & pumped all fluid out. Any thoughts?
/ Massey power steering hard left #2
Yeah--what kind of Massey?
it is a 165 year unknown at this time
/ Massey power steering hard left #4
G'day remove the grill and check the valve on the steering ram is working correctly make sure the link pin is moving the valve in and out you cannot have any looseness in the connectinc pins at all or you will not get it to steer correctly.
Jon
/ Massey power steering hard left #5
If it's a 165, your problem is most likely in the control valve linkage and/or adjustment. The whole package is behind the grill, in front of the radiator. The pins and links that operate the valve spool become worn over time and adjustment becomes necessary. Wear and excessive play in the shafts and bushings throughout the system are also a factor, Often these bushings haven't seen grease in years. As a rule, I would check the valve linkage with the engine off first. Open the grill and dust off the linkage enough to see what's going on. Then grab the draglink and try to force it by hand in both directions. There should be enough freeplay to move the control valve linkage enough to see movement of the valve spool in both directions. The valve is spring loaded to neutral and should remain there until some effort is applied to move it one way or the other. In your case, I suspect something is either out of place or out of adjustment causing the valve to be somewhere other than neutral when the steering is at rest.That causes the steering to take off on it's own when you start the engine.
Thanks very much for the replies, will do exactly what you guys suggest and let you know the results!
40' One-Trip Shipping Container (A66285)
40' One-Trip...
1980 Yamaha Sun Classic Golf Cart (A66408)
1980 Yamaha Sun...
2013 CATERPILLAR 299D SKID STEER (A65053)
2013 CATERPILLAR...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2017 Gravely ZT-X 52in Zero Turn Commercial Mower (A64194)
2017 Gravely ZT-X...
