Do you balance your trailer tires?
/ Do you balance your trailer tires? #11
Put new tires on a 16 ft dual axle bumper pull last year and had them balanced. When towing with tractor loaded cannot tell much of difference but when empty or lightly loaded the balancing seemed to make it tow a good deal smoother.
/ Do you balance your trailer tires? #12
Balance them. Like stated before, when towing empty it makes a huge difference.
Chris
/ Do you balance your trailer tires? #13
I have 4 trailers. none of the tires are balanced
/ Do you balance your trailer tires? #15
I balance the tires of any highway use tire... Why not ? besides a little extra cost ... nothing compared to the cost of the tire.
Yep, I think I will. I never balanced a trailer tire in 20+ years, but I own a trailer now that has much lighter axles than my old one. It has 5200 lb torflex (6,000 standard duty), and 15 inch tires. I'm swapping out the 15" D rated tires for a set of E rated towmasters-figure a heavier tire never hurt. Thanks for all the replies.
UPDATE: Just my opinions...... I had the tires balanced. Honestly, I can't feel a difference. the trailer is about 4000lb empty, and have only pulled it empty since balancing them. I know it doesn't hurt to balance them, but no difference.... to me. maybe if it was a lighter trailer?
/ Do you balance your trailer tires? #18
IMO, on a lighter trailer, an out-of-balance tire is going to be more obvious. Not to say, that on a heavier trailer, the same problem tire won't start to wear funny even if you can't feel it in the truck.
Some people don't bother, but unless the trailer never left the farm, or only went 5 miles to the dump and back, I'd want it balanced. Just my preference, and :2cents:.
Enjoy the new tires, they should serve you well.
Rgds, D.
2014 FORD F-550 XL SUPER DUTY UTILTY/SERVICE TRK (A59823)
2014 FORD F-550 XL...
203201 (A60429)
203201 (A60429)
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A60736)
CAT FORKS W/ QUICK...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
2006 Mercedes-Benz ML350 AWD SUV (A59231)
2006 Mercedes-Benz...
