Building hydraulic pump for dump trailer
/ Building hydraulic pump for dump trailer #1
luc2121
ontario canada
2005 tc45da 1998 zetor 3320
I just recently built a dump trailer from an old tandem dump trailer, problem is the big multi section telescopic cylinder holds lots of oil, more than my john deere 6120 has or close to it. Trying to think of a way to build a hydraulic driven pump to use with a reservoir to lift it. Was thinking of bolting 2 pumps together using one as a moter and other as a pump. Anyone ever do this ? Or other ideas. Was going to try pto pump but would need a valve to release pressure etc
Thanks luc
/ Building hydraulic pump for dump trailer #2
Thanks luc
I would suggest using a hydraulic motor to drive the hydrualic pump Vs using a pump as a motor. Yes it is has been done and will work. Any reason why you could not use the PTO to drive a pump?
I could but trying to figure out how configure a valve to raise it and be able to hold in up position and then be able to lower it
/ Building hydraulic pump for dump trailer #4
JJ how would i plumb the valve ? The cylinder is single acting with only one fitting
Thanks
/ Building hydraulic pump for dump trailer #8
http://www.surpluscenter.com/item.asp?item=9-1047-1&catname=hydraulic
9.9 GPM @ 2250 psi
Raise time about 1 min.
The pump OUT put/pressure side goes to the valve IN port.
Pump suction comes from tank.
Valve OUT port goes to tank through filter.
Either use a single action valve or a DA valve and plug the A work portt.
Single action valve
http://www.surpluscenter.com/item.asp?item=9-6763&catname=hydraulic
Double action vales.
B port goes to cyl.
http://www.surpluscenter.com/item.asp?item=9-7861&catname=hydraulic
http://www.surpluscenter.com/item.asp?item=9-7974&catname=hydraulic
Thanks for the info and help JJ ,
