Interesting Double Pull
/ Interesting Double Pull #1
Diamondpilot
Super Star Member
Daleville, IN
Jinma 254/284 Ford 861 Powermaster at work
Seen a new one on my way to the lake. I see double pulls every weekend but usually involves a pickup. This was a odd combo.
Chris
/ Interesting Double Pull #2
You guys are allowed to do that?
Forbidden here.
/ Interesting Double Pull #4
Could be interesting trying to back that trailer in far enough to float the boat with a motorhome...
Aaron Z
/ Interesting Double Pull #7
I'm pretty sure aczlan knew that and was just being a tad facetious. :)
Was thinking that they might do that, but wondering if a Jeep Patriot (which that appears to be) would have enough traction to pull a boat big enough to require a 7k trailer out of the water.
Aaron Z
/ Interesting Double Pull #8
Aaron Z
I think it is a Liberty. I don't think it would have too much problem in low range. The ramps around us aren't the greatest. Many are shallow so it would be tricky to get a sailboat trailer in far enough to float the boat off the trailer.
/ Interesting Double Pull #9
Could be. Even with an extending tongue, that will be a beast to get into the water.
Aaron Z
/ Interesting Double Pull #10
Aaron Z
OK, and I was thinking is was a joke about unloading the boat with the Jeep still attached. :) Oops!
I think the Liberty would do fine just towing it around the campground to the ramp and out though. On the highway, I think the boat would be a bit much for the Jeep.
/ Interesting Double Pull #11
The way some people drive, I wouldn't be surprised to see that...
I guess the pulling it out part would depend on the weight of the boat... The problem isn't usually getting the boat/trailer into the water, its getting it back out.
Aaron Z
/ Interesting Double Pull #12
Ain't that the truth!
Aaron Z
Definitely! The weight of the water and the force it takes to pull the boat out is tremendous. Would probably need 4-Low in that little Jeep to have a shot. I learned to drive backing a boat trailer down the ramp when I was about 13 or 14. Nothing like first learning to drive backwards with a trailer attached. :)
/ Interesting Double Pull #13
'Double pulls' are allowed here in MI, too.
"Under Section 721 of the Michigan Vehicle Code, pickup trucks equipped with a fifth-wheel assembly may, with certain restrictions, tow two trailers. This double trailer combination is sometimes called a 'recreational double'. Drivers must pass a knowledge test to receive their 'recreational double' endorsement.
Definition:
A recreational double is a pickup truck pulling a fifth-wheel trailer, designed for recreational living purposes, with a second trailer attached to the rear of the fifth-wheel trailer. The pickup truck must have a towing rating equal to, or greater than, the weight being towed.
To operate a recreational double, drivers must have an è¿* endorsement on their license. Applicants must pass a test designed to sample the knowledge needed to operate vehicle combinations of this type. Drivers who have a Group A Commercial Driver License with a å…¸ (double trailers) endorsement may legally operate a recreational double without obtaining the è¿* endorsement.
The total length of the three units pickup truck, fifth-wheel trailer and second trailer when coupled together, must not exceed 75 feet. The gross weight of the second trailer cannot exceed the empty weight of the pickup truck or the empty weight of the fifth-wheel trailer. The hitch used to tow the second trailer must be attached to the frame of the fifth-wheel trailer."
A few hoops to jump through, but do-able. No mention of a tow bar for the second item towed, but the above rules should apply.
btw: If I had a sailboat like that you couldn't give me a MH. It's a lot easier to sleep on a boat than it is to fish or dive from a motorhome, but that's just me. ;)
/ Interesting Double Pull #14
Chris
Stupid guy forgot his plane.........:laughing:
Forbidden here.
Do it all the time. I have pulled a 33' boat with a Jet Ski behind.
I bet truck, boat, and ski were 65 to 70' long.
I see it done 10 times over every weekend at my marina. Usually truck, 30' camper, 21' boat.
Chris
Aaron Z
Most sailboat trailers at our marina have tongue's that extend 15' or more.
No issue. That boat is onlt 4000# or so.
Chris
/ Interesting Double Pull #17
I guess it'll just depend on the launching ramp to get that kind of boat deep enough. I didn't have any trouble launching a 28' pontoon boat with my 40' Bounder motorhome.
/ Interesting Double Pull #18
I think it is only legal with a fifth wheel trailer pulling a bumper pull trailer (or towed vehicle) lighter than itself.
/ Interesting Double Pull #19
That is an awfully long load.
I know that my grandfather wanted to use:
Pickup to pull 5th wheel travel trailer to pull a very small boat.
And was told that it was not legal to do in Oregon. He argued that he had a CDL (for log trucks), but the DMV would not budge for recreational use. Obviously, if one person does it, then everyone would want to do it.
And, we do have triple trailer trucks on the highways, often Bread trucks and UPS trucks.
/ Interesting Double Pull #20
Chris
Marinas will also hoist the boat off the trailer and set it in the water for him. It is the safest way to launch with a long trailer. Even an empty trailer gets hard to retrieve after the wheels drop off the end of the ramp.
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
2006 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2006 MACK CHN613...
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2011 International DuraStar 4300 Mobile Food Prep Truck (A64194)
2011 International...
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
