? About pallet forks for 3320
/ ? About pallet forks for 3320 #1
Angora Animal
Angora, MN
John Deere 3320
Hi all,
I'm wondering what ppl's recommend for a set of forks for the 3320. I do have the CX loader. Oddly I haven't really seen this on the threads; I posted this in the JD forum in hopes of feedback from JD owners specifically. Thanx!!
-AA
/ ? About pallet forks for 3320 #2
I have the Artillian forks on my 3320 and have been very pleased with them. They are really well made.
/ ? About pallet forks for 3320 #3
I have Horst 48" with sliding forks. the adjustable feature is very handy. They work well for my purpose, but have nothing to compare. Got them from my son when he sold his JD CUT.
/ ? About pallet forks for 3320 #4
There are lots of choices. I prefer 48inch over the shorter ones. The extra length lets you see the tips a little better, which is difficult at times.
/ ? About pallet forks for 3320 #5
Same here, I have the Artillian forks and very pleased with them.
/ ? About pallet forks for 3320 #6
I have a combination pallet fork/bale spike for my 300CX. The forks are sliding but require manhandling IOT switch between them and the bale spike option.
That's not (that much) of a problem right now, but I'm not getting any younger & those forks are bloody heavy!
/ ? About pallet forks for 3320 #7
artillian? i have a naybor that has the reptilian ones that have more strnght
/ ? About pallet forks for 3320 #8
If you have some flat concrete, raise your forks about 16 inches off the ground and then tilt them forward so the tips just lightly touch the ground. They will slide side to side a lot easier.
/ ? About pallet forks for 3320 #9
that guy probably wasn't thiking to well that day. i though that was elementary physics
/ ? About pallet forks for 3320 #10
Darn
I took (and passed) college based physics (calculus based at that) and I didn't think of it. Must be too many years between my degree and me getting a tractor. But I am sure going to try it next time I have the forks on :thumbsup:
/ ? About pallet forks for 3320 #11
Sorry Mate, you misunderstood. I was talking about mounting the two individual pallet fork tynes, not sliding them back & forth. My bale spike 'option' is a single unit (also heavy) that slides into the same frame, replacing the fork tynes. :)
(Later edit) I've re-read your post and realised that you didn't misunderstand, you were addressing a situation within my post. Thank you for the above suggestion, I'll give it a go the next time I have the fork tynes mounted.
/ ? About pallet forks for 3320 #12
Noodles, as much as I like you, I've got to say....why don't we start with grammar and spelling, then progress to teaching others about physics. Then finally, work on the art of intelligent conversation.
LOL. I never considered the idea of being able to see the end of the forks...hmm. Good tip.
-AA
/ ? About pallet forks for 3320 #14
The Horst Welding forks work well for my 200CX plus they will paint them JD green for you. They are very well built and I have found that they stay on the loader more than the bucket. Horst Welding | Family of Companies I even saved on freight when the delivery dealer waited to include the forks with a regular shipment.
/ ? About pallet forks for 3320 #15
Agree with John. Picture of mine. Horst light duty. Works great.
Henri
/ ? About pallet forks for 3320 #16
Hiya,
I had a set of Host light duty for my 2520, when I sold it I sold the forks too as they are only rated for 1200 Lbs and the 300cx has a higher capacity than that. I went with the Deere forks over the Artilian's as they hadn't designed the back stop for them yet and I needed them day 1 with the 3320. Deere forks do what forks should however lining them up is more difficult than the Horst as the Horst's have additional plates to line up the top part of the JD connector.
Tom
Tom
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2018 Kubota...
2009 POLAR TANK TRAILER (A67714)
2009 POLAR TANK...
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
PAIR OF FRAC TANK STANDS (A68842)
PAIR OF FRAC TANK...
Vortex Walk-Behind Paint Sprayer (A64553)
Vortex Walk-Behind...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
