1978 Cadet 1650 Not Charging
   / 1978 Cadet 1650 Not Charging #1
ollie2009
My trusty old 1650 looks like it is not charging. Yesterday after cutting grass for about 30 minutes, the motor started to cut out. As soon as I turned off the electric clutch the motor limped back to life, and then ran as usual. Soon as i turned on the electric clutch again, same thing. Turned it back off and then went back to the garage. Shut it down, and went for lunch. After coming back, it would not start. Put the battery on the charger for a few hours, and when tried to start it after supper, started up great. After cutting grass for about 20 minutes or so, same thing. This time after shutting the clutch off and letting engine get back up to speed, when I turned the clutch back on, I noticed that the voltmeter registered a discharge. Turning off the clutch and voltmeter went to 12V (on the guage), but never charged any higher then that.
Can anyone give me some troubleshooting advice on how to find out why it's not charging. Would really appreciate any help you can offer.
   / 1978 Cadet 1650 Not Charging #2
It's been awhile since I had my 1450 but if I remember correctly the alternator is under the flywheel. There is a rectifier assembly mounted on the lower part of the engine by 2 screws. This is most likely the failing part. You can check for AC voltage from the alternator going into it. You should be getting 13.5-14.5 VDC to the battery.
Bob B.
   / 1978 Cadet 1650 Not Charging #3
I found this posting here you might take a look at. He had the same problem. Cub 1650 not charging
I recently overhauled my charging circuit. What happened was the same symtoms as yours. What I found was a flywheel dropped a couple of magnets and destroyed the stater (alternator) and the stator took out the rectifier/regulator. I found a good used stator on eBay. The flywheel bought new from Kohler. Bought the recifier off ebay. Just a word of advice. If you have to replace the flywheel. Spend the extra buck and buy a new one. A used one might lose the magnets too. The new ones have improved bonding adhesive. -kid
   / 1978 Cadet 1650 Not Charging #4
if you do not want to spend extra bucks on older unit, i have used jb weld and have successfully rebonded magnets to flywheel.on many unit's
   / 1978 Cadet 1650 Not Charging #5
Yes sir, JB weld would probably fix it till one of the other magnets let go. Personally I wouldn't trust a flywheel that just destroyed my stator on another stator. It's well documented on the net that the older flywheels where prone to have magnets come loose. So where do you get replacement magnets, and how to do verify correct orientation so the field is not interrupted? -kid
   / 1978 Cadet 1650 Not Charging #6
you will see the old glue spots on the wheel for proper orientation,buying a flywheel will solve the prob's fine, BUT some flywheel's are no longer avail,if you are buying a used one on ebay,might have the same prob
   / 1978 Cadet 1650 Not Charging #7
My 25 Hp Kohler is no longer made nor is the original flywheel. They sold me an upgraded version where I had to cut two small ears off the plastic shroud that covered it. Reattaching the magnets on mine was not an option. The magnet(s) came lose and destroyed the stator. The magnets where also destroyed. Chances of a magnet coming loose and surviving are probably slim to none. I have pictures of the mess if you doubt my word. Exact replacement may not be available. But one that will work I'm sure is. The only item I bought used was the stator. It was a 15 amp stator that was removed from a blown engine.
His problem of not charging if it's not the battery is probably a damaged stator like mine was. It is a very common problem with older engines. You should know that of all people here. Putting a bandaid on the problem is a poor recipe of a repair on equipment you intend to keep. If the OP wants to patch his pride and joy that is certainly an option. From the picture he provided I for one would want my vintage collectible repaired properly. The old saying. "You can pay me now, or pay me later" comes to mind when patching something of this nature. Then again I'm not in the patch repair business either. Your mileage may vary. -kid
   / 1978 Cadet 1650 Not Charging #8
yes well said "pay me now or pay me later that's why i keep saying use the proper tranny fluid in the 2000,3000 series tractors, just quoting you...
   / 1978 Cadet 1650 Not Charging #9
What? I was talking about a flywheel.. :confused: -kid
Tried replying before, but looks like it didn't go.
I am just now getting at my tractor, and would like some troubleshooting tips. To check the stator integrity, would I just do a continuity check across both wires coming from the stator? Can I check the rectifier with a multimeter? Or do I have to have it conected, the tractor running and just measure the voltage on the 3rd terminal on the rectifier to ground to see if I am getting voltage? Any tips you can offer would be greatly appreciated.
Thanks
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
Ih 490 Disk (A50514)
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
