Cub Cadet Zero Turn Tank Comerical
   / Cub Cadet Zero Turn Tank Comerical #1
leftybob
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I purchased this machine last year and I'm trying to find the greese fitting for the mower spindles. I was told they may not have any if they are sealed ball bearings & not roller bearinge like my other mowed decks have. Any one know for sure? I think it is an 02 year model.
   / Cub Cadet Zero Turn Tank Comerical #2
Find the machine's I D plate. Write down the machine's FULL model # and serial number from the plate. Go to this website:PDF Manual Web Archive, enter those numbers. You should be able to download an owners manual and possibly a parts list for that particular machine. From that, you should be able to know for sure about how the spindles are set up.... zerks or no zerks.
Some deck spindles have the zerks up on top, some under the belt/pulley shields, some under the deck itself.
   / Cub Cadet Zero Turn Tank Comerical #3
You might find this link interesting. It's a training manual for the Tank or certain repairs and belt replacements. Bookmark it for sure.
http://service.mtdproducts.com/Training_Education/769-01760/769-01760_SM_MMZ.pdf
   / Cub Cadet Zero Turn Tank Comerical #4
Interesting - Good info, Kid... OP, on Pp 10 of that pdf file there is a pix of a disassembled spindle - magnify it to about 400x and you will see the grease zerk and cast boss on the spindle hsg where it is located.... mebbe that will help you find yers..?
   / Cub Cadet Zero Turn Tank Comerical #6
nice link,thanks def bookmark that one...glad
Better yet, download thePDF file and save it. The link may one day go away. Once the PDF file loads, you should have an option to save it locally.
2018 Caterpillar 287D Compact Track Loader Skid Steer (A55787)
2018 Caterpillar...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2015 New Holland T4.95 MFWD Cab Tractor (A55302)
2015 New Holland...
1990 C Hawk 22Ft. Boat with T/A Boat Trailer (A55758)
1990 C Hawk 22Ft...
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
Giyi 59" Vibrating Roller (A53316)
Giyi 59" Vibrating...
