Looking for a 4-6 row planter
/ Looking for a 4-6 row planter #1
2006gmcdmax
Gold Member
Augusta, GA
Many but mostly ford diesels or ihc or jds
Ok I'm wanting to start farming about 100 acres here soon. I have a ford 5000 and was thinking a 4-6 row 30" spacing would work. I was going to put some yetter trash whippers on the front and kind of turn it into a no till along with Keaton seed firmers. What would be the best planter for me, a four or six, a John Deere or int? I would spend up to 5000. If I have to build I will I hear the 70s -76s are good jd planters I could put 4-6 on a tool bar maybe which kind of would be perfect?
/ Looking for a 4-6 row planter #2
I have no experience with international planters. I have always used 6 and 8 row deeres. These planters are heavy. I feel like a 6 row is going to be too much for your tractor. Especially if you are adding no till packages to it. I think you will be happier with a 4 row 30 in setup.
That's what I was thinking also I wonder if I built a tool bar 4 row of course put yetter brush whippets on it and then inch wide wavy coulters then pulled my planter if that would work
/ Looking for a 4-6 row planter #4
In that style planter I would suggest the JD 71s as they are really good planters. There are some good IH planters (465?) also, but parts/plates availability for the 71’s is very good and probably will be for a long time. Yetter is still building a version of the 71’s today. I don’t recall ever seeing trash sweeps for the 71s, but I have never really looked for them.
I would also look into a set of 4 row JD 7000 or 7100 planter pull type (if you have rear remotes). I have seen them listed with no-till openers that were within/around your budget. Personally, I perfer strip till over no till but that's another subject and it requires more HP.
71s iv heard nothing but good about them as well. I was wanting something alittle more modern that is accurate I wanting to start farming on the side just to make some extra money really.
And by the way 7000s were what I was kind of looking for
/ Looking for a 4-6 row planter #7
Just for your information, a 7000 is a pull type and the 7100 is a 3ph version. Thats the only difference in the two. If you already knew this just disregard it. Just trying to help without coming off as a "know it all".
Yessir in fact I did I'm not sure weather I'd rather have a three point or pull behind three point would be good for turning at the end either or I think would do me now just time to find one
/ Looking for a 4-6 row planter #9
I like the 3pt. Makes turning around at the headlands a snap. But im really not sure if your tractor will have enough lift capacity and/or height to handle a 4 row 7100 with full seed boxes and no-till coulters and such. A 7000 may suit you better. Surely someone else here has tried a 7100 on a tractor like yours and can give a more definate answer.
Sure enough if I buy this 1086 with ac and a cab I'm sure shell be about to lift it no problem. My ford does have remotes as well so a 7000 would work. Far as the no till I might make a tool bar where ill have to make two runs one with the tools and second with the planter
/ Looking for a 4-6 row planter #11
That 1086 will pack a 8 row easy. I estimate i've planted 20-25k acres of corn with a 8 row 7100 behind a 986. You may find that a 7000 or 7100 will plant no-till without all the add on's. When we went to no-till we just used our 8 row planter for 3 years before I found a used 6 row with no-till coulters and springs. The 8 row planted great except in very hard dry soils. That was the only conditions that i saw the need for the wavy coulters and down pressure springs. I personally never saw the need for row sweepers, even in heavy corn stubble or wheat straw.
That's what I was thinking maybe adding some tractor weights to the planter and try that. And cool deal well ill definitely try it without. And yeah an old guy I know has a 1086 he wants 7500 for the sheet metal is perfect so is the interior very nice clean tractor needs a paint job wished it was a 66 or 56 series though. Do all 7000s and 7100s have feet boxes on them or no
Also I wonder if the kinze meters would be good to throw on the jds and maybe those keeton seed firmers would you know anything about these two item as well
/ Looking for a 4-6 row planter #14
They are hard to find around here with fert boxes on em. Have no experience with the kinze meters. Tried the lil firmer things. Didnt really see any real advantage to them. Those planters do a good enough job of firming the soil around the seed without any help.
Oh yeah, that sounds like a good deal for the 1086.
Seems to be worth leaving alone then how do you get firtilizer in the grown planting if it doesn't have any fert boxes cause feet boxes will actually be set about 2 inches on the left or right of what your planting correct?
/ Looking for a 4-6 row planter #16
We broadcst fert preplant for corn and beans. Then side dressed with liquid N solution for corn. Lots of disagreement on the subject but my thoughts along with all the other farmers around me and our crop advisors is that the roots of the plants stretch well beyond the center of the row so getting the fert right next to the row is not nessacary.
What all will I need for liquid nitrogen and usually liquid nitrogen you fo that at 4" then once again at tractor axle higth correct?also what do you mean broadcast fert with like a spreader or sprayer and is liquid fert or granular better?
/ Looking for a 4-6 row planter #18
I think the fertilizer with the planter is just an extra starter shot. I have been trying to get started growing sweet corn. First year I used my nephew's 4 row with fertilizer and was way under fertilized. Next 2 years I backed off trying to figure out our real needs up here in the frozen north. This year I got a JD 7100 cut down to 2 rows with fertilizer. I fertilized the field heavily broadcast before planting and went with what the planter guy recommended for fertilizer rate for the side dressing. Good thing I don't depend on the corn for a living - by the time I figure all the rates out I'll drop dead.
/ Looking for a 4-6 row planter #19
Broadcast granular fert preplant. And we used an 8 row liquid applicator for one application after the corn got a foot tall. It is a pull type unit that the co-op supplied to its customers. Applied 100 units of n-solution.
Haha yeah seems like broadcasting may be wasting fertilizer but **** it's there probably last 2 or three years ain't nothing a soil sample won't tell you. Basically what I plant to do which this will be my first year is I plan to kill everything with round up spread fertilizer plant corn and soy beans I guess fert again if needs and let it grown harvest and do it again
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
150 GALLON FUEL TANKS WITH BRACKETS (A65643)
150 GALLON FUEL...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
