Y1700 pressure problem
/ Y1700 pressure problem #1
sirgknight
South Georgia
Early model YM1700
While mowing weeds I noticed that my right front axle looked very wet so I drove the tractor back to the yard. Oil was being lightly spewed from the oil filler cap. I loosened the cap slightly and the pressure started easing out so I left the cap in place. I then pulled the dipstick and the pressure blew oil all over my shirt and took the dipstick completely out of my hand. After letting the tractor cool down I checked the oil level and it was full. I checked the radiator and it was also full. The spewed oil was all over the engine and front axle area. The tractor never ran hot and never sounded abnormal. What would cause that kind of pressure in the oil without any warning?
Your crankcase vent is stopped up. Reference 35 here. Yanmar Tractor Parts: BLOCK
You are so right.......dag-gummed dirt dobber had the little pipe completely sealed. Thanks for solving my problem. I would have never figured that one out. I just knew I had an internal motor problem....again thanks for the help.
/ Y1700 pressure problem #4
Bee's,Yellow Jackets even ants are bad in Ga.Get a piece of clear Tube so you can see through it. Like this. You can see through it when your looking at it.:ashamed: Under your seat is a U-Tube that is the Hyd.vent. There bad about getting in there also;)
thanks, I'll check that one also. I have some clear tubing from my medical supplies that should work great. Thanks for the tip.
2015 Chevrolet Silverado 2500 (A62613)
2015 Chevrolet...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
40' One-Trip Shipping Container (A66285)
40' One-Trip...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
Grace Quick Attach Tree Puller (A66408)
Grace Quick Attach...
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
