Rotary Cutter Is my bushhog too heavy
   / Is my bushhog too heavy #1
bm3
warsaw va
MF 1635 , JD 3203 , JD 1070
My JD 3203 has been running a 5 ft international heavy duty cutter . I have to tie the 3 point lever to my seat to stop it from dragging the ground , it will just drop to the ground and drag if I don't . When its raised all the way up then it will stay but only when raised all the way . The darn thing is rated for a 5 ft bushhog , when asked the service manager at Deere he said it must be too heavy , well it does not weigh over 450 lbs , any thoughts would help . I tie the control lever to the side to prevent it from lowering on its own
   / Is my bushhog too heavy #2
I would assume the lifting capacity for your 3pt hitch is much more than what your cutter weighs. Are you having a linkage issued, which may be why your having to tie off your lever.
Everything appeared to be alright but I'll check over it again , thanks
   / Is my bushhog too heavy #4
Does your lever move very easily. There should be some friction at its pivot that keeps the lever from moving on its own. There should be a way to adjust that. Just wedging something lightly next to the lever should do the same.
larry
   / Is my bushhog too heavy #5
are you saying tht the 3pt lever by your seat will drop and then the laod drops? or is it a inching type valve like some orange tractors with a center neutrl, and a incremental up lift when moved up.. and you are having to keep it up in the 'lift' area to keep the mower up.. and if you let it center the mower drops. if the latter.. i'd say you have a lift leak. if the former.. then your 3pt lever may need some sort of friction adjustment.
re-describe the problem and add as many details as you can based on our questions and descriptions to help us understand the exact nature of the issue.
   / Is my bushhog too heavy #6
Your tractor will handle that hog easily...
You probably have a linkage issue...
   / Is my bushhog too heavy #7
bm3:
When my new-to-me Kubota had the same problem, I hooked up the chains and chain plates I used on my old Bolens G174. The attached link has the details, and a source for the parts. The system works well. No fuss. I mow around 25 acres of little trees.
Hope this helps,
Rod
Bush hogging with the Kubota B7510 (continued) | Walnut Diary
   / Is my bushhog too heavy #8
My Ford has a stop on the 3pt height adjustment lever.
I don't like it, so I normally push it down to the bottom. This is designed so it only obscures half of the 3pt height adjustment slot, so one can easily push the lever to the side and around.
I haven't noticed the 3pt hitch ever "leaking down". I don't see a simple tension adjustment, but that undoubtedly would vary by tractor.
I think our old IH had something similar.
If there is only one slot, one could add a similar stop, but wouldn't have the simple bypass.
Its the first , I have to tie the lever to the side of the seat when I have it at the right position . I was concerned about harming something by doing that . If I raise it up all the way then it will stay . Deere said its not a leak or it would not stay up. Will not stay in any position other than all the way up.
   / Is my bushhog too heavy #10
Does the tractor have a draft control on it?
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2005 Chevrolet Colorado 4x4 Pickup Truck (A55852)
2005 Chevrolet...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
