Concrete Mixers
/ Concrete Mixers #1
TrevorM
Rosetown, Saskatchewan
Kubota
Hello All, I was a member here years ago when I bought my Kubota (still love my tractor). I own a flighting company out of Rosetown, Saskatchewan, Canada. I am looking for a trailer type concrete mixer, 1-2 bag capacity. I found most on the market tow horribly because of the narrow wheel width and they are top heavy. I am looking for any information of some towable concrete mixers that tow better. Any help would be appreciated. Thanks alot.
/ Concrete Mixers #2
Welcome to TBN.:tractor:
/ Concrete Mixers #3
Goto to mixright.com. They look pricy though. Welcome to TractorByNet.
/ Concrete Mixers #6
I don't think you are going to find anything that size that's really towable. Are we talking about on road (truck) towing or off road (tractor)? In that size, nothing is really going to be towable.
I have a Harbor Freight 3-1/2 cu ft mixer and it will handle two bags. It looks like you would expect a cheap Chinese mixer to look, but it works fine. It's light enough to move easily and you could either load it onto a small utility trailer or a 3 point platform.
/ Concrete Mixers #9
If you read the manuals on those small mixers they usually say that they are "not for towing on the road". Same with most log splitters. The wheels and bearings are not up to it and are only for moving them around your lot. Much safer to put it in a trailer to haul it.
/ Concrete Mixers #10
I've had one of these from Canoga Equipment since 1993. Towed it to jobsites for years, with a lot of freeway driving. Mine mixes one sack just fine, but if you're looking to mix larger quantities, they make the 300 series too.
If you do get a drum type mixer, always tow with the drum facing upwards. It looks like your towing a mini nuclear plant, but all that bouncing with that heavy drum facing down shortens the life of the bearing a bunch.
/ Concrete Mixers #11
Just to clarify...If you're looking for a cement mixer that will mix one 90 lb sack of cement plus aggregates, the one I referred to will work out great. If you're talking about a mixer that will mix one or two bags of concrete, you're better off buying a tub, heavy duty mixing drill and paddle bit. Way faster and more portable than the cheap little mixers.
/ Concrete Mixers #12
Yep that one looks like proper road tires and axle. Decent looking unit.
2004 Chevrolet Silverado Pickup Truck, VIN # 1GCEK19T04E260216 (A61165)
2004 Chevrolet...
AIR VENT INC (A62131)
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
2006 UTILITY V2 T/A 53X102 REFRIGERATED TRAILER (A59909)
2006 UTILITY V2...
208492 (A62130)
208492 (A62130)
2012 Range Rover SUV (A61569)
2012 Range Rover...
