Ck weird electrical.
   / Ck weird electrical. #11
On the DK the combination switch (headlight/tailight and horn) gets its battery feed from a terminal on the ignition switch. So it the combination switch has power when the (ignition or starter switch) is turned to OFF.. well that aint right. so there is a corrosion bridge or something in the ignition/starter switch or something... any chance of a rat? chewed wires and made some new connections. I would want to measure for voltage on B1 terminal of the Combination switch, which should not be there if the ignition/starter switch is turned off. This wire is 1/2 mm in size and yellow in color. But I am assuming all of this is similar to the DK and I don't know that it is.
   / Ck weird electrical. #12
Oh, man I strained to read yours,.. but I saw enough to see that they are not the same.. Where does Lead marked B+ to to that comes up out of the combination switch B1 terminal? on the DK it goes to the key switch, M terminal, but it doesnt seem to on yours.
Thanks james. We don't have rats here but we do have mice. I have traps set in the shop but have never caught one. Nor have I ever seen poop. I'm tracing the chain of events in my mind and thinking its almost certainly water from washing. I did give it a full wash before this happened. I'm thinking there is moisture in a connector somewhere. I have blown some out with compressed air and moisture did come out. Problem persists. I'm sure there is dozens if connectors I can't see.
   / Ck weird electrical. #14
Check to see if there is a visitor chewing on your wiring, like a mouse, or similar.
   / Ck weird electrical. #15
It is quite a bit different than the DK.. I would bet on the water angle too. Might be easiest to let the dealer fix it. Did you use a pressure washer? They can put water in a lot of places you did not intend.
   / Ck weird electrical. #16
I am thinking the the B+ goes directly to the battery. now that feeds both the low beam and the high beam relays. Relay could possibly be stuck. or some stray voltage in a connector is powering the coil to energize it. Would have to have good readable schematic layed out and a voltmeter to hunt this one down..If I was in your garage tonite with my tools I would help you fix it, but I am a little far.
I didn't use a pressure washer but I did hose it down real good :-(
Tomorrow I will spend some time checking connectors. Just wish I know what specific areas to target. I can't understand those schematics. Lol
   / Ck weird electrical. #20
Ignition switch issues on these rigs came to mind concerning the lights part of your issue and as others say check for rodents.
2006 USH BOAT & 2012 TL (A56859)
2006 USH BOAT &...
NEW Fork Extensions (A59000)
NEW Fork...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
